Home » Archived » BPMN Modeler » Can't download BPMN Modeler
Can't download BPMN Modeler [message #540118] Tue, 15 June 2010 02:43 Go to next message
Luis Bola is currently offline Luis BolaFriend
Greetings, I was trying to download BPMN Modeler from the STP update site (http://download.eclipse.org/stp/updates/site.xml) using eclipse's update manager, however when I do so, it shows the following error:
Network connection problems encountered during search.
Unable to access "http://download.eclipse.org/stp/updates/site.xml".
Unable to access site: "http://download.eclipse.org/stp/updates/site.xml" [Server returned HTTP response code: "404 Not Found" for URL: http://download.eclipse.org/stp/updates/site.xml.]
According to that message, the site is down or the files has been moved to a new site. Does anyone know what could it be? Any Suggestions? alternatives?
Thanks! Razz
Re: Can't download BPMN Modeler [message #540124 is a reply to message #540118] Tue, 15 June 2010 05:18 Go to previous messageGo to next message
Verena is currently offline VerenaFriend
use this one for Galileo:
http://download.eclipse.org/stp/updates/galileo/
Or this one for Helios:
http://download.eclipse.org/stp/updates/helios/
HTH,
--Verena
Re: Can't download BPMN Modeler [message #540262 is a reply to message #540124] Tue, 15 June 2010 13:36 Go to previous messageGo to next message
Hi Verena.
When I try to use both sites, it shows me the same "404 Not Found" error.
Any suggestion? Am I doing something wrong?
Re: Can't download BPMN Modeler [message #540413 is a reply to message #540118] Wed, 16 June 2010 05:37 Go to previous message
You're probably doing something wrong. I just reached the update site without any problems.
Did you remember to configure the Internet connection within Eclipse?
Preferences->General->Network Connections
Previous Topic:Old Versions of BPMN-Plugin
Next Topic:Download
Current Time: Sun Aug 09 12:35:28 GMT 2020
Powered by FUDForum. Page generated in 0.02417 seconds
