Xerces version conflict [message #4850] |
Tue, 12 November 2002 15:26 |
Originally posted by: hayden.unicorn.com
I would like to use Eclipse XSD as standalone, and I see that it used the
Xerces plugin 4.0.7. I looked on the Apache Xerces site and I see versions
Xerces 1 to 1.44 and Xerces 2, but I don't see Xerces 4.0.*.
The reason that I am concerned is that in the application that I would
like to embed the XSD into we are using Xerces 1.44. If 4.0.* is the new
generation then I would like to port our application to use it. However I
didn't have any luck finding out about this.
Re: Xerces version conflict [message #4994 is a reply to message #4850] |
Tue, 12 November 2002 14:57 |
Hayden,
All the version numbering is so very confusing. :-(
According to the plugin, the real Xerces version is some 2.0.0 stream:
<!-- This is an IBM maintenance branch of xerces 2.0.0 -->
We've only tested with the version of Xerces in Eclipse.
When I need Javadoc for Xerces, I get the latest 2.x from Apache, but I use
the jars in Eclipse to actually compile and run. That hasn't caused me any
problems yet so maybe it will work for you...
> Thanks
Ed Merks
Re: Xerces version conflict [message #563677 is a reply to message #4850] |
Ed Merks Messages: 33139 Registered: July 2009 |
Hayden,
> Thanks
Ed Merks
Ed Merks
FUDForum. Page generated in 0.02688 seconds
