Home » Eclipse Projects » Plugin Development Environment (PDE) » p2 director application - blindly pull in all IUs from a repo?
Re: p2 director application - blindly pull in all IUs from a repo? [message #541198 is a reply to message #540053] |
Fri, 18 June 2010 15:59 |
Troy Nichols Messages: 28 Registered: July 2009 |
Thanks, Andrew.
Fortunately I think I can avoid that, now that I know a little more
about what's available. For the record, I was able to use the p2.mirror
task to accomplish what I needed, by mirroring the contents of
repositories I needed into my product's build repo, then doing the
product build (with ranged requirements specified in p2.inf).
This article
http://aniefer.blogspot.com/2009/07/composing-and-updating-c ustom-eclipse.html
helped me out a lot, so thanks.
-Troy
Andrew Niefer wrote:
> You would have to do this programmatically yourself.
> You can take a look at the implementation of that director application, some
> minor changes could get it to install everything.
> from the org.eclipse.equinox.p2.director.app bundle, the
> DirectorApplication#performProvisioningActions() does the install. There
> are collections of things to install and things to uninstall.
> To get all the IUs from the repo, you would do a query on the repository
> like this:
> IQueryResult<IInstallableUnit> everything =
> collectRootIUs(QueryUtil.createIUAnyQuery());
> -Andrew
> Troy Nichols wrote:
>> Hi, p2 director question:
>> When I run the director (command line) to install an IU from a
>> particular p2 repo, it requires me to provide the argument -installIU
>> [some IU], to tell it which things from that repo it should install.
>> But if I've built my own custom p2 repo (for use just in a build, in my
>> case), I want to blindly take everything in that repo instead of having
>> to specify which feature I want. Based on the director application's
>> available arguments as shown here:
> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/p2_director.html
>> there doesn't seem to be a way to do it. Is there some other way to
>> (programatically) install *everything* from a given p2 repo into a given
>> target?
>> Thanks.
Re: p2 director application - blindly pull in all IUs from a repo? [message #606112 is a reply to message #540053] |
Thanks, Andrew.
This article
-Troy
> like this:
> -Andrew
>> target?
>> Thanks.
Current Time: Thu Mar 28 22:24:59 GMT 2024
Powered by FUDForum. Page generated in 0.02473 seconds
