Home » Modeling » Modeling (top-level project) » Which is the best model to use in PHP with eclpise?(Which is the best model to use in PHP with eclpise?)
Which is the best model to use in PHP with eclpise? [message #539547] Fri, 11 June 2010 09:07 Go to next message
xescjp Mising name is currently offline xescjp Mising nameFriend
Hello everybody.
I am quite new on eclipse.
I have been reading about programing in PHP using MVC model. I have learned how it works. After that I started to look for a free PHP IDE. I found eclipse but I don't know if I can use a framework that implements MVC on eclipse. Is this possible? Is possible to use zend framework in eclipse?
If not, which model can be used in eclipse? I must install any framework?
Thanks a lot in advance.
xescjp
Re: Which is the best model to use in PHP with eclpise? [message #539628 is a reply to message #539547] Fri, 11 June 2010 14:37 Go to previous message
Xescjp,
The modeling project doesn't provide anything frameworks that directly
(out of the box) works with PHP.
xescjp wrote:
> Hello everybody. I am quite new on eclipse.
> framework in eclipse? If not, which model can be used in eclipse? I
> xescjp
Ed Merks
Re: Which is the best model to use in PHP with eclpise? [message #619644 is a reply to message #539547] Fri, 11 June 2010 14:37 Go to previous message
Xescjp,
> xescjp
Ed Merks
Previous Topic:[Graphiti] Proposal
Next Topic:[Announce] Modeling Survey 2010
Current Time: Wed Feb 28 20:27:08 GMT 2024
Powered by FUDForum. Page generated in 0.02079 seconds
