Home » Language IDEs » Java Development Tools (JDT) » Cannot install new software (after Ubuntu upgrade)
Cannot install new software (after Ubuntu upgrade) [message #539349] Thu, 10 June 2010 14:02 Go to next message
Luca Ferrari is currently offline Luca FerrariFriend
After an upgrade from ubuntu 9.1 to 10.04 Eclipse starts, but all extensions I've installed (egit, hg and so on) are missing. More interesting, if I try to Install New Software nothing happens, that means I don't see any dialog opening and I found this exception into the log:
!ENTRY org.eclipse.osgi 4 0 2010-06-10 15:58:12.112
!MESSAGE
!STACK 0
java.io.IOException: Manager is not opened.
        at org.eclipse.osgi.storagemanager.StorageManager.add(StorageManager.java:217)
        at org.eclipse.osgi.storagemanager.StorageManager.closeOutputStream(StorageManager.java:883)
        at org.eclipse.osgi.storagemanager.ManagedOutputStream.close(ManagedOutputStream.java:52)
        at java.io.FilterOutputStream.close(FilterOutputStream.java:143)
        at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveBundleDatas(BaseStorage.java:566)
        at org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllData(BaseStorage.java:433)
        at org.eclipse.osgi.internal.baseadaptor.BaseStorage.frameworkStop(BaseStorage.java:834)
        at org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStop(BaseAdaptor.java:262)
        at org.eclipse.osgi.framework.internal.core.SystemBundleActivator.stop(SystemBundleActivator.java:72)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:843)
        at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:836)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.suspendAllBundles(StartLevelManager.java:623)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:265)
        at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:216)
        at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:266)
        at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:685)
        at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:583)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:409)
        at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:200)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
        at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
        at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
Any idea on how to fix it?
Re: Cannot install new software (after Ubuntu upgrade) [message #539434 is a reply to message #539349] Thu, 10 June 2010 17:12 Go to previous messageGo to next message
Prakash G.R. is currently offline Prakash G.R.Friend
> log:
> !MESSAGE !STACK 0
> at
> org.eclipse.osgi.storagemanager.StorageManager.add(StorageMa nager.java:217)
> at
> org.eclipse.osgi.storagemanager.StorageManager.closeOutputSt ream(StorageManager.java:883)
Sounds like a bug to me. Open a bug:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Equinox
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Cannot install new software (after Ubuntu upgrade) [message #539696 is a reply to message #539434] Fri, 11 June 2010 21:24 Go to previous messageGo to next message
Thanks, bug 316656 opened. Hope it will be solved very soon.
Re: Cannot install new software (after Ubuntu upgrade) [message #539920 is a reply to message #539696] Mon, 14 June 2010 09:51 Go to previous message
I found in the logs another interesting information about wrong permissions on
/usr/lib/eclipse/p2/org.eclipse.equinox.p2.engine/profileRegistry/PlatformProfile.profile/.lock
adjusting permissions solved the problem of the missing install new software dialog. Then I installed all the software I needed without having any error, but the software seems not to work, and now in my logs I found:
!SESSION 2010-06-14 11:43:44.504 -----------------------------------------------
eclipse.buildId=M20100211-1343
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86_64
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.330
!MESSAGE The installable unit org.eclipse.cdt.core.linux.translated_host_properties is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.331
!MESSAGE The installable unit org.eclipse.equinox.executable_root.cocoa.macosx.x86_64 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.motif.hpux.ia64_32 is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.332
!MESSAGE The installable unit org.eclipse.equinox.executable_root.win32.win32.x86 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.motif.linux.x86 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.gtk.solaris.x86 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.motif.hpux.PA_RISC is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.333
!MESSAGE The installable unit org.eclipse.equinox.executable_root.win32.win32.ia64 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.motif.solaris.sparc is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.cocoa.macosx.x86 is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.334
!MESSAGE The installable unit org.eclipse.equinox.executable_root.carbon.macosx.x86 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.win32.win32.x86_64 is missing the filename property.
!MESSAGE The installable unit org.eclipse.cdt.core.linux.x86_64.translated_host_properties is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.335
!MESSAGE The installable unit org.eclipse.equinox.executable_root.gtk.solaris.sparc is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.gtk.linux.x86_64 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.photon.qnx.x86 is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.336
!MESSAGE The installable unit org.eclipse.equinox.executable_root.gtk.linux.x86 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.carbon.macosx.ppc is missing the filename property.
!ENTRY org.eclipse.equinox.p2.directorywatcher 4 0 2010-06-14 11:44:03.337
!MESSAGE The installable unit org.eclipse.equinox.executable_root.wpf.win32.x86 is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.gtk.linux.ppc is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.cocoa.macosx.ppc is missing the filename property.
!MESSAGE The installable unit org.eclipse.equinox.executable_root.motif.aix.ppc is missing the filename property.
!ENTRY org.eclipse.equinox.p2.engine 4 4 2010-06-14 11:44:05.544
!MESSAGE An error occurred while installing the items
!SUBENTRY 1 org.eclipse.equinox.p2.engine 4 0 2010-06-14 11:44:05.544
!MESSAGE session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.provisional.p2.engine.phases.Install, operand=null --> [R]org.eclipse.equinox.executable_root 3.3.200.R35x_v20090724-7M-FneFF9aMTyz0pw04ONXn, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.UnzipAction).
!SUBENTRY 1 org.eclipse.equinox.p2.touchpoint.natives 4 0 2010-06-14 11:44:05.544
!MESSAGE The artifact for binary,org.eclipse.equinox.executable_root,3.3.200.R35x_v20090724-7M-FneFF9aMTyz0pw04ONXn is not available.
Moreover, digging the log, I discovered that the software plugins were not installed as I thought:
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-06-14 11:41:21.310
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.ui 4 10050 2010-06-14 11:41:21.310
!MESSAGE Cannot complete the request.  See the error log for details.
!SUBENTRY 1 org.eclipse.equinox.p2.ui 2 10005 2010-06-14 11:41:21.311
!MESSAGE "Eclipse JGit (Incubation)" will be ignored because it is already installed.
The problem is that the software is installed, but it is not available (not loaded).
Previous Topic:Problem with Eclipse editor
Next Topic:How to get value os selected item from SWT TABLE
Current Time: Fri Sep 18 11:02:59 GMT 2020
Powered by FUDForum. Page generated in 0.02028 seconds
