Home » Eclipse Projects » Rich Client Platform (RCP) » Please help, Distinguish enter key event in Editor
Please help, Distinguish enter key event in Editor [message #539110] Wed, 09 June 2010 16:07 Go to next message
Jeffery Yuan is currently offline Jeffery YuanFriend
Hi, all:
I have a command line application, and want to develop a rcp application to provide more functions, such as syntax check and highlight, content assistant, quick fix ect.
Here is my problem:
After user enters the command in the editor, I need to capture the enter key event and call cli method.
I tried this in TextEditor.createPartControl(Composite):
this.getSourceViewer().getTextWidget().addKeyListener(
        new KeyListener() {
            public void keyReleased(KeyEvent e) {
            public void keyPressed(KeyEvent e) {
                if (e.keyCode == SWT.CR) {
                    // call cli method here
                    System.out.println("Executing the command");
                    callCli();
but the editor also provides content assistant function, when user inputs prefix of one command or one option, the editor will immediately open a popup and let user select. in this case, the callCli method would also be executed.
How can I distinguish the enter keyevent when user select these choices from popup window from that enter when user wants to execute the command.
Thanks very much for the reply and help : )
btw, one option is to let user enter "ctrl+enter" to execute command, but this is not a pratical and user-friendly choice.
[Updated on: Wed, 09 June 2010 16:07]
Report message to a moderator
Re: Please help, Distinguish enter key event in Editor [message #539933 is a reply to message #539110] Mon, 14 June 2010 10:21 Go to previous messageGo to next message
Dani Megert is currently offline Dani MegertFriend
yuanyun.ken wrote:
> Hi, all:
> Here is my problem:
> new KeyListener() {
> callCli();
> the command.
You can add an
org.eclipse.jface.text.contentassist.ContentAssistant.addCom pletionListener(ICompletionListener)
to your editor's content assistant.
Dani
> btw, one option is to let user enter "ctrl+cr" to execute
Re: Please help, Distinguish enter key event in Editor [message #540116 is a reply to message #539110] Tue, 15 June 2010 02:02 Go to previous messageGo to next message
Hi, Dani:
Thanks very much for the reply, and it works.
I add CompletionListener to the ContentAssistant, when assistSession starts or ends, I set two flags, through the two flags, I can know whether the enter happens in content assist, and allow or cancel the enter operation accordingly.
the code is as following:
    public class CliConfiguration extends SourceViewerConfiguration {
	private boolean contentAssistSessionStarted = false;
	private boolean contentAssistSessionEnded = false;
	public IContentAssistant getContentAssistant(ISourceViewer sourceViewer) {
		ContentAssistant assistant = new ContentAssistant();
		assistant.addCompletionListener(new ICompletionListener() {
			public void selectionChanged(ICompletionProposal proposal,boolean smartToggle) {
			public void assistSessionStarted(ContentAssistEvent event) {
				contentAssistSessionStarted = true;
			public void assistSessionEnded(ContentAssistEvent event) {
				contentAssistSessionEnded = true;
		return assistant;
public class CliCmdInputEditor extends TextEditor {
	public void createPartControl(Composite parent) {
		super.createPartControl(parent);
		this.getSourceViewer().getTextWidget().addVerifyKeyListener(new VerifyKeyListener() {
			public void verifyKey(VerifyEvent e) {
				if (e.character == SWT.CR || e.character == SWT.LF) {
					if (cliConfiguration.hitEnterKeyInContentAssit()) {
						// do nothing, and allow enter key
						System.out
								.println("the enter key happened in content assist");
						return;
                                        // cancel enter operation, and call cli method.
					System.err.println("call cli method here");
					e.doit = false;
[Updated on: Tue, 15 June 2010 04:07]
Re: Please help, Distinguish enter key event in Editor [message #541434 is a reply to message #539110] Mon, 21 June 2010 07:35 Go to previous message
An update to this post, the previous way is problematic.
Instead we can check event.doit property directly:
-- A flag indicating whether the operation should be allowed. Setting this field to false will cancel the operation.
if the enter key happens in content assist, event.doit is set as false:
so the code is as below:
				if (e.doit == false) {
					return;
                                        // don't output newline here
                                        e.doit = false;
[Updated on: Tue, 22 June 2010 06:39]
Previous Topic:Sleeping Jobs in ProgressView
Next Topic:Tableviewer hide lines at empty rows
Current Time: Mon Jan 24 11:39:46 GMT 2022
Powered by FUDForum. Page generated in 0.02355 seconds
