Home » Archived » M2M (model-to-model transformation) » [ATL] Two output models serialized into the same file?(It works sometimes...Bug?)
[ATL] Two output models serialized into the same file? [message #539049] Wed, 09 June 2010 09:21 Go to next message
Hi list:
I've been using the following header, to create a SINGLE file containing elements from two meta-models:
create OUT1 : UML, OUT2 : EST from IN1 : SIM;
This works sometimes.
1) Is this allowed in ATL?
2) If yes, why does it work only sometimes?
Thanks in advance!
Re: [ATL] Two output models serialized into the same file? [message #539795 is a reply to message #539049] Sun, 13 June 2010 04:08 Go to previous message
Hi Alex,
your EST is a UML Pofile, Thus you can use all Stereotypes and also all standard UML elements (Class, Package, Attribute etc...) as first class elements in your ATL transformation.
e.g.
rule myRule{
to
xyz : EST!Class ...
zyx : EST!FunctionType(
base_Class <- xyz,
Thus you must not do something like:
do{
xyz.applyStereotype(...);
xyz.setValue(...);
From my point of view, you do not need to state two output models explicitely.
The only thing you have to keep in mind is, that you must apply all Profiles (EAST Profile and explicitely all necessary sub Profiles from the EAST Profile) on the output model manualy with pure old Java Code (see uml2 package Model.applyProfile(...)) after the transformation has been done. A post processing so to say. Without doing that, no profiles will be applied on the output model when using the Profile EAST as metamodel.
Cheers, Helko
[Updated on: Sun, 13 June 2010 04:12] by Moderator
Previous Topic:[QVTo] Extract port conjugation from an RSA-RTE model
Next Topic:[ATL] Problem with keywords
Current Time: Wed Jul 09 05:56:58 EDT 2025
Powered by FUDForum. Page generated in 0.50303 seconds
