Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Editable columns of tree viewer(How to make columns of tree viewer editable)
Editable columns of tree viewer [message #538631] Tue, 08 June 2010 09:14 Go to next message
vrush Mising nameFriend
Member
I have tree viewer with two columns as property and value. I need to make 2nd column editable. Tried setting column editors and column properties as follows but not able to edit any column.
Code snippet :
viewer = new TreeViewer(parent, SWT.SINGLE | SWT.H_SCROLL | SWT.V_SCROLL | SWT.FULL_SELECTION);
viewer.setColumnProperties(new String[] {"Property","Value"});
viewer.setCellEditors(new CellEditor[]{new TextCellEditor(viewer.getTree()), new TextCellEditor(viewer.getTree())});
viewer.setCellModifier(new ICellModifier() {
public void modify(Object element, String property, Object value) {
System.out.println("propertyName\t" + property);
public Object getValue(Object element, String property) {
return null;
public boolean canModify(Object element, String property) {
return true;
viewer.setContentProvider(new ViewContentProvider());
viewer.setLabelProvider(new ViewLabelProvider());
viewer.setSorter(new NameSorter());
Please suggest if missing anything. Stuck.
Any help would be grateful.
Vrushali.
Re: Editable columns of tree viewer [message #538657 is a reply to message #538631] Tue, 08 June 2010 11:05 Go to previous messageGo to next message
Vijay RajFriend
return null;
should not return a null value
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
Re: Editable columns of tree viewer [message #538909 is a reply to message #538631] Wed, 09 June 2010 04:39 Go to previous messageGo to next message
Member
Thanks for your reply. I tried returning some random string from the function getValue() but still it does not seem to be working. I'm not even getting editable text.
I'm referring to snippet
http://bingjava.appspot.com/snippet.jsp?id=2206
I need the same functionality in treeviewer with columns.
Can you/anyone please look through and suggest missings?
Thanks again in advance,
Vrushali.
Re: Editable columns of tree viewer [message #538999 is a reply to message #538631] Wed, 09 June 2010 10:04 Go to previous message
Member
Thanks for rightly pointing out mistake. Its working now.
Thanks a lot,
Vrushali.
Previous Topic:How to get OS X standard menubar behavior?
Next Topic:ExpandBar not expanded properly
Current Time: Fri May 14 18:01:42 GMT 2021
Powered by FUDForum. Page generated in 0.02334 seconds
