Home » Eclipse Projects » Remote Application Platform (RAP) » [ Titanic ] java.net.SocketException: Too many open files
Re: [ Titanic ] java.net.SocketException: Too many open files [message #538311 is a reply to message #538115] |
Mon, 07 June 2010 10:10 |
Hi Christian,
this can't be related to the bug you mentioned since the handling of
resources works completely different in RAP. The theming images you
refer to are read once and registered as static resources with the HTTP
service. The file handles are immediately released after this.
Maybe the servlet container keeps some file handles open for whatever
reasons? Is the list of open handles static or does it change frequently?
Ralf
Tingel Christian wrote:
> Hi RAP team:
> I know there is a similar issue about this problem that has long lasted
> for 7 years in eclipse platform and mostly occured in Eclipse IDE.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=42986
> Unfortunately, we knocked into this iceberg in RAP recently, really mass
> destruction.
> We found that over 400 handlers had been used to handle
> org.eclipse.rap.ui/context/resource/static/image/blank.gif and over 400
> for files something like "
> org.eclipse.rap.ui/context/resource/themes/Custom_1/widgets/
> ctabfolder/close.gif " or
> "org.eclipse.rap.ui/context/resource/themes/images/148ab7bc"
> what I would like to know is: does the problem here in RAP share the
> same root cause with the Eclipse IDE? Do we have any other ideas to
> workarround it than modifying the max file handlers of the OS?
> the problem occurs on Linux whose default max file handler is 1024, and
> our RAP version is: 1.2.0, the container is Tomcat 6.0.20.
> Any suggestion will be greatly appreciated.
> Thanks and Best Regards
> Yours: Tingel Christian
Re: [ Titanic ] java.net.SocketException: Too many open files [message #538396 is a reply to message #538342] |
Mon, 07 June 2010 14:40 |
> Hi Ralf:
> The handlers relative to blank.gif and images such as close.gif and
> maxmize.gif etc are static, but the ones relative to random numbers
> something like context/resource/themes/images/c3558a6c are not static~~~
> would it be better if I file a bug?
Unless there are a) many open filehandles for the same file or b) many
filehandles kept open over a long time, I don't think that there is a
bug in RAP. If the list of opened files changes frequently and does not
grow continuously than I'd guess that the server is just under heavy
load. After all, Tomcat needs to open files in order to deliver them.
This exception seems to be a common problem with Tomcat/Linux. There are
many threads out there explaining how to increase the limit for open
file handles.
Anyway, if you think there is a bug in RAP, feel free to report it.
Ralf
> Ralf Sternberg wrote on Mon, 07 June 2010 18:10
>> Hi Christian,
>> Ralf
>> > Hi RAP team:
>> lasted
>> really mass
>> > destruction.
>> 1024, and
Re: [ Titanic ] java.net.SocketException: Too many open files [message #538408 is a reply to message #538396] |
Mon, 07 June 2010 15:11 |
tingel christian Messages: 46 Registered: December 2009 |
Member |
Thanks, Ralf~~~
I am sorry to say that but you know, there are more than 400 handlers dealing with the same file blank.gif when there is no concurrent sessions requests, I think it really incredible~~~
The painful point is that increasing the upper limit for open file handlers is strictly prohibited by our clients, So...
I am now planning to have a test using Jetty, do you think that would be better?Cos I do realized that most of the out of handlers cases are related with Tomcat~~~
Tingel Christian
Ralf Sternberg wrote on Mon, 07 June 2010 22:40 | Tingel Christian wrote:
> Hi Ralf:
file handles.
Ralf
>> Hi Christian,
>> Ralf
>> > Hi RAP team:
>> lasted
>> really mass
>> > destruction.
>> 1024, and
Re: [ Titanic ] java.net.SocketException: Too many open files [message #538411 is a reply to message #538408] |
Mon, 07 June 2010 15:24 |
> Thanks, Ralf~~~
400 open handles for the same file is strange. If you can reproduce it,
please open a bug.
> handlers is strictly prohibited by our clients, So... :cry: :cry:
at least I cannot reproduce the problem with Jetty running the RAP demo
from Eclipse.
>> > Hi Ralf:
>> static~~~
>> file handles.
>> Ralf
>> >> Hi Christian,
>> HTTP
>> frequently?
>> >> Ralf
>> >> > Hi RAP team:
>> >> lasted
>> >> really mass
>> >> > destruction.
>> over 400
>> share the
>> >> 1024, and
Current Time: Fri Apr 19 18:59:08 GMT 2024
Powered by FUDForum. Page generated in 0.03729 seconds
