Re: Classpath dependancy validator warning [message #538106 is a reply to message #538095] |
Sat, 05 June 2010 04:13 |
On 6/4/2010 4:26 PM, Phil Freihofner wrote:
> I am curious what, if anything, to do with the following warning (from
> the "Markers" tab):
> Classpath entry
> org.eclipse.datatools.connectivity.jdt.DRIVERLIBRARY/Postgre SQL JDBC
> Driver will not be exported or published. Runtime
> ClassNotFoundExceptions may result.
> Indeed, in the project in question, I get a ClassNotFound exception.
> Where can I learn about this? I don't see anything in the Connectivity
> properties that says anything about exporting or not.
> In scrutinizing the various warning messages, I also have a warning
> during the startup of the Apache server:
> INFO: The APR based Apache Tomcat Native library which allows optimal
> performance in production environments was not found on the
> java.library.path: [long path list here]
> And:
> WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting
> property 'source' to 'org.eclipse.jst.jee.server:Nearby' did not find a
> matching property.
> What is the significance of these?
> In part, this is a continuation of exploring a question I have in
> earlier. Hopefully the different emphasis of the question will prevent
> this from being perceived as a double post, and I promise to follow up
> in each context as appropriate.
> Thanks!
I believe what you're seeing is this.
In Java Build Path -> Libraries you have libraries, other than the JRE
System Library, that contribute to your project. If you plan on
deploying the application to a container like Tomcat, you need to decide
whether and which of the libraries to copy to the WAR for that purpose.
This is done by selecting them in Properties -> Java EE Module
Dependencies. Once you do this, I think your warnings will disappear.
Your container may already offer some of the libraries you otherwise
must add to your project. So, you might decline to fix this. However, if
you can't run when you deploy, then this is an indication that you
should include the JARs containing the missing symbols.
Hope this is a) accurate and b) that it helps.
Russ Bateman
Re: Classpath dependancy validator warning [message #538137 is a reply to message #538112] |
Sat, 05 June 2010 15:10 |
On 6/5/2010 12:20 AM, Phil Freihofner wrote:
> Thank you so much!
> I was a bit thrown by the use of the term WAR, as the project was not
> built from a WAR, and I don't understand where this is located. But I
> was able to find a reference to the PostgreSQL Driver in "Properties ->
> Java EE Module Dependencies" as you described, and it was unchecked.
> Upon checking it, the Marker warning disappeared, and the program did
> find and connect to the database when I ran it.
> This has been one of the hardest things I have ever tried to figure out,
> and I am very, very grateful to you for taking the time to answer my
> question.
You're certainly welcome Phil. Check out
http://www.javahotchocolate.com/ for stuff like this.
I write to prove to myself that I grok. And why not drop bread crumbs
for the next Hansel and Gretl that come along?
Russ
Re: Classpath dependancy validator warning [message #634493 is a reply to message #634491] |
Thu, 21 October 2010 23:43 |
On 2010.10.21 17:27, Phil Freihofner wrote:
> Hi - I am now using a different setup and am getting this same error.
> Unfortunatly, the solution does not seem to be possible in this new
> context.
> Error warning:
> Classpath Dependency Validator Message
> Classpath entry
> org.eclipse.datatools.connectivity.jdt.DRIVERLIBRARY/MySQL JDBC Driver
> will not be exported or published. Runtime ClassNotFoundExceptions may
> result.
> I am now using:
> Eclipse Java EE IDE for Web Developers.
> Version: Helios Release
> Build id: 20100617-1415
> I am using Tomcat 7.0.2.
> The JDBC driver was added to the Build Path via AddLibrary>Connectivity
> Driver Definition. The same method of adding this driver code works for
> a different project that does NOT use Apache.
> Previously, I was able to select the project's "Properties>Java EE
> Module Dependencies". With this new version of Eclipse, the "Java EE
> Module Dependencies" does not exist, and I am having trouble trying to
> determine what the equivalent might be.
> Many thanks!
> Phil Freihofner
You must ask this in the eclipse webtools forum if you want an answer.
This is exactly why I don't use Helios for web-application development.
I think they broke this aspect of WTP for Helios and only the super
gurus are able to work around it or explain how it's done instead of
using the old Java EE Module Dependencies configuration. I still don't
get how to do it, but Galileo works perfectly, so I haven't stressed
over it. For WTP stuff (and Android for now), I just stay with Galileo.
Otherwise, Helios works well.
Re: Classpath dependancy validator warning [message #870859 is a reply to message #634504] |
Thu, 10 May 2012 03:08 |
I've been searching for a solution to this "warning" for a while now and thanks to this thread, I got the answer! Thanks and can you believe that I'm using RAD 8 with all the latest fixes and it still has the problem that Phil points out...that the warning and error doesn't go away but when I deploy it, it works fine!
Thanks to Phil for mentioning that. Otherwise, I'd be banging my head for nothing.
Re: Classpath dependancy validator warning [message #1844338 is a reply to message #1844287] |
Thu, 09 September 2021 19:16 |
Fundamentally the message is telling you that you've added a library to the Java Build Path that won't
be published with the web app, and that usually leads to runtime errors. You can mark it for deployment
using the Deployment Assembly property page. The message may stick around until you Build or Validate
the project.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.08759 seconds
