Home » Archived » M2M (model-to-model transformation) » Possible to reference to two helpers in the same rule
Possible to reference to two helpers in the same rule [message #538036] Fri, 04 June 2010 15:23 Go to next message
Roger80  is currently offline Roger80 Friend
Member
Hi all,
I have two helpers defined for one rule defined. How can I add a second helper to the same rule?
My code looks like this:
rule Event {
from
	e : EPK!Event (not e.isStarter()), (not isConditionalFlow()) --does not work
to
	b : BPMN!IntermediateThrowEvent
		id <- e.id,
	 	name <- e.name
Re: Possible to reference to two helpers in the same rule [message #538046 is a reply to message #538036] Fri, 04 June 2010 16:19 Go to previous messageGo to next message
Sylvain EVEILLARD is currently offline Sylvain EVEILLARDFriend
not e.isStarter() and not e.isConditionalFlow()
Re: Possible to reference to two helpers in the same rule [message #538048 is a reply to message #538046] Fri, 04 June 2010 16:26 Go to previous messageGo to next message
Member
it doesn't work...
rule Event {
from
	e : EPK!Event (not e.isStarter()) and (not isConditionalFlow())
to
What do I make wrong?
Re: Possible to reference to two helpers in the same rule [message #538049 is a reply to message #538036] Fri, 04 June 2010 16:29 Go to previous message
Member
Perfect, sorry its working with:
rule Event {
from
	e : EPK!Event (not e.isStarter() and not e.isConditionalFlow())
to
Thanks for your help!!!!!
Previous Topic:[ATL] Problem with Helper in Rule
Next Topic:[ATL] How to make an ecore from XSD and its XML?
Current Time: Sat Dec 14 16:37:50 GMT 2024
Powered by FUDForum. Page generated in 0.02925 seconds
