Ubuntu (Unix) Postgresql. OSEE Server Not starting? [message #537706] |
Thu, 03 June 2010 12:28  |
al  Messages: 22 Registered: June 2010 |
My Question is: Based on the server log, did it start correctly & if not where would I start to find out the root cause?
Below you will see the following:
1) My Server Setup
2) Start up Script
3) Console output from server statup
4) Server Log file
My Environment setup:
ubuntu-10.04-server-i386 in a Virtual Machine,
Postgresql 8.4.4 (Has been configured for OSEE)
Start up Script:
java -Dosee.log.default=INFO -Declipse.ignoreApp=true -Dorg.osgi.service.http.port=8089 -Dosgi.compatibility.bootdelegation=true -Xms40m -Xmx512m -Dosee.db.connection.id=postgresqlLocalhost -Dosee.application.server.data="/home/gis2gps/oseeAppServer_postgres_0.9.1/data " -Dequinox.ds.debug=true -jar org.eclipse.osgi.jar -console
Here is the start up output for the OSEE Server:
I see an exception referencing "osee_server_lookup" what is it?
osgi> Thu Jun 03 05:14:28 PDT 2010 org.eclipse.osee.framework.database.internal.InternalActivat or
INFO org.eclipse.osee.framework.database.internal.DbConnectionInf ormation bind (70)
binding org.eclipse.osee.demo.db.connection.DemoDbConnectionInfo@ae533a
INFO org.eclipse.osee.framework.database.internal.parser.DbConfig Parser getAllDbServices (50)
in getAllDbServices 3
INFO org.eclipse.osee.framework.database.internal.DbConnectionInf ormation bind (74)
osee.microdoc: jdbc:postgresql://78.46.71.230:5432/OSEE : user=osee
postgresqlLocalhost: jdbc:postgresql://localhost:5432/OSEE : user=osee
derby: jdbc:derby://127.0.0.1:1621/DerbyDatabase; : user=osee
binding org.eclipse.osee.framework.database.internal.UriDbConnection Info @1f1235b
Adding: org.eclipse.osee.framework.core.server.internal.ServerDataba seProvider @7c3885
Thu Jun 03 05:14:28 PDT 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.internal.ServerTaskSc heduler addServerTask (41)
Adding task: Clean up join tables
Thu Jun 03 05:14:29 PDT 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.OseeServerProperties getOseeApplicationServerData (69)
Application Server Data: [/home/gis2gps/oseeAppServer_postgres_0.9.1/data]
Registered servlet '/osee/manager'
Registered servlet '/osee/resource'
Registered servlet '/GET.ARTIFACT'
Registered servlet '/osee/artifact'
Registered servlet '/index'
Registered servlet '/osee/branch/exchange'
Registered servlet '/osee/branch'
Registered servlet '/osee/search'
Registered servlet '/osee/search/tagger'
Registered servlet '/osee/server/lookup'
Registered servlet '/osee/session'
Registered servlet '/osee/client/loopback'
Registered servlet '/osee/install/info'
Registered servlet '/osee/cache'
Registered servlet '/osee/model'
Thu Jun 03 05:14:31 PDT 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore getOseeVersionsByServerId (195)
Server lookup table is not initialized
Thu Jun 03 05:14:31 PDT 2010 org.eclipse.osee.framework.database.internal.InternalActivat or
SEVERE org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl runBatchUpdate (158)
This is the nested exception
org.postgresql.util.PSQLException: ERROR: relation "osee_server_lookup" does not exist
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorRespons e(QueryExecutorImpl.java:1608)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(Quer yExecutorImpl.java:1343)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecut orImpl.java:343)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(Abs tractJdbc2Statement.java:2668)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.runBatchUpdate(OseeDatabaseServiceImpl.java:14 9)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.runBatchUpdate(OseeDatabaseServiceImpl.java:17 2)
at org.eclipse.osee.framework.database.core.ConnectionHandler.r unBatchUpdate(ConnectionHandler.java:81)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore.deregisterWithDb(ApplicationServerDataStore.j ava:74)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.writeToDataStore(InternalOseeServerInfo.java:114)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.updateRegistration(InternalOseeServerInfo.java:12 2)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager.executeLookupRegistration(ApplicationServerMana ger.java:87)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager$1.run(ApplicationServerManager.java:56)
at java.util.TimerThread.mainLoop(Timer.java:534)
at java.util.TimerThread.run(Timer.java:484)
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore deregisterWithDb (77)
Server lookup table not initialized
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore.registerWithDb(ApplicationServerDataStore.jav a:94)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.writeToDataStore(InternalOseeServerInfo.java:115)
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore registerWithDb (97)
Thu Jun 03 05:14:32 PDT 2010 org.eclipse.osee.framework.search.engine.internal.SearchEngi neTagger
INFO org.eclipse.osee.framework.search.engine.internal.StartUpRun nable run (45)
Tagging on Server Startup was not run.
Server Log file:
!SESSION 2010-06-03 05:25:00.171 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_18
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -console
!ENTRY org.eclipse.osgi 4 0 2010-06-03 05:25:00.646
!MESSAGE Bundle plugins/org.eclipse.osee.framework.oracle@3:start not found.
!ENTRY org.eclipse.osgi 2 1 2010-06-03 05:25:00.865
!MESSAGE NLS missing message: SERVICE_REFERENCE_BOUND in: org.eclipse.equinox.internal.ds.SCRmessages
[Updated on: Thu, 03 June 2010 18:10] Report message to a moderator
Re: Ubuntu (Unix) Postgresql. OSEE Server Not starting? [message #538291 is a reply to message #537706] |
Mon, 07 June 2010 09:08   |
Mark D-B Messages: 188 Registered: July 2009 |
This may not be the whole problem, but it looks to be like you are pointing the binary data repository at the same place as the database.
Is ="/home/gis2gps/oseeAppServer_postgres_0.9.1/data" the location of your PostgreSQL data? If so, this should not be where osee.application.server.data is set. osee.application.server.data specifies the location of the binary data (i.e. large lumps of data from attributes such as Native Content or Word OLE Content which are zipped and stored outside the database to prevent excessivedatabase growth and poor backup performance), not the database. PostgreSQL handles the database location itself.
You can ommit the definition and OSEE will put it in the home directory of the user running the server, which is probably the best thing to do until you have things up and running. You can move it afterwards.
Also, why are you using such a long command line? The arguments should already be set in the application server's config.ini.
[Updated on: Mon, 07 June 2010 09:09] Report message to a moderator
Re: Ubuntu (Unix) Postgresql. OSEE Server Not starting? [message #543547 is a reply to message #537706] |
Tue, 29 June 2010 18:01   |
then I try to Initialize the database
Initialization script is is from the documentation :
../eclipse/eclipse -nosplash -application org.eclipse.osee.framework.database.init.configClient -console -vmargs -XX:MaxPermSize=256m -Xmx512m -Dosee.application.server=http://127.0.0.1:8089
Yet It seems as if its trying to start another server instance......
and I get the following:
osgi> 2010-06-29 10:54:42.247::WARN: failed SelectChannelConnector@0.0.0.0:80
java.net.SocketException: Permission denied
at sun.nio.ch.Net.bind(Native Method)
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelI mpl.java:137)
at sun.nio.ch.ServerSocketAdaptor.bind(ServerSocketAdaptor.java :77)
at org.mortbay.jetty.nio.SelectChannelConnector.open(SelectChan nelConnector.java:216)
at org.mortbay.jetty.nio.SelectChannelConnector.doStart(SelectC hannelConnector.java:315)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCy cle.java:50)
at org.mortbay.jetty.Server.doStart(Server.java:233)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager.up dated(HttpServerManager.java:109)
at org.eclipse.equinox.http.jetty.internal.Activator.start(Acti vator.java:60)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:774)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:557)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:464)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:248)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:445)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
2010-06-29 10:54:42.248::WARN: failed Server@11dba45
Registered servlet '/osee/unsubscribe'
Registered servlet '/osee/ats'
Tue Jun 29 10:54:47 PDT 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
SEVERE org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager$1 run (61)
No DB connection information provided
java.lang.IllegalStateException: No DB connection information provided
at org.eclipse.osee.framework.database.internal.DbConnectionInf ormation.getSelectedDatabaseInfo(DbConnectionInformation.jav a:62)
at org.eclipse.osee.framework.database.core.DatabaseInfoManager .getDefault(DatabaseInfoManager.java:31)
at org.eclipse.osee.framework.core.server.internal.ServerDataba seProvider.getDatabaseInfo(ServerDatabaseProvider.java:31)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.getDatabaseInfoProvider(OseeDatabaseServiceImp l.java:47)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.getDefaultConnectionPool(OseeDatabaseServiceIm pl.java:51)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.getStatement(OseeDatabaseServiceImpl.java:86)
at org.eclipse.osee.framework.database.core.ConnectionHandler.g etStatement(ConnectionHandler.java:53)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore.getOseeVersionsByServerId(ApplicationServerDa taStore.java:186)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.updateVersionsFromDataStore(InternalOseeServerInf o.java:62)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.updateRegistration(InternalOseeServerInfo.java:12 0)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager.executeLookupRegistration(ApplicationServerMana ger.java:90)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager$1.run(ApplicationServerManager.java:59)
[Updated on: Tue, 29 June 2010 18:03] Report message to a moderator
FUDForum. Page generated in 0.02323 seconds
