Home » Modeling » GMF (Graphical Modeling Framework) » Probelm with GenerateDiagramCode ant task
Probelm with GenerateDiagramCode ant task [message #537621] Thu, 03 June 2010 05:56 Go to next message
Hi All,
I tried generating the diagram editor code using the GenerateDiagramCode ant task.
I have installed plugin for GMF Ant task usign the link
site: http://www.eclipticalsoftware.com/updates/site.xml
I have also added the tag xmlns:gmf="http://ecliptical.ca/gmf/ant in the build.xml. This tag has no error.But when i tried to run the task "GenerateDiagramCode" am getting the exception "org.eclipse.core.runtime.CoreException: Model loaded with errors. uri=platform:/resource/./model/spectrial.gmfgen"
If anybody have an idea about this kind of exception please do reply.Its bit urgent.
Thanks in advance,
login
Re: Probelm with GenerateDiagramCode ant task [message #537872 is a reply to message #537621] Thu, 03 June 2010 23:33 Go to previous messageGo to next message
Hi login,
Do you get a stack trace at all?
Jevon
login wrote:
> Hi All,
> site: http://www.eclipticalsoftware.com/updates/site.xml I have also
> Thanks in advance,
> login
Re: Probelm with GenerateDiagramCode ant task [message #537887 is a reply to message #537872] Fri, 04 June 2010 05:05 Go to previous message
Hi Jevon,
I dint get any stack trace for this task.
I just got the following error in the console.
In error log i couldnt find any exception.
Buildfile: C:\CDEWorkspace\spectrial\build.xml
apitools.generation:
run:
BUILD FAILED
C:\CDEWorkspace\spectrial\build.xml:90: org.eclipse.core.runtime.CoreException: Model loaded with errors. uri=platform:/resource/./model/spectrial.gmfgen
Total time: 266 milliseconds
Previous Topic:Design Label uses GMF icons instead of XXX.edit icons
Next Topic:How to empty a property field
Current Time: Thu Feb 13 09:54:55 GMT 2025
Powered by FUDForum. Page generated in 0.31338 seconds
