Re: Iterate over all heap instances? [message #537815 is a reply to message #537791] |
Thu, 03 June 2010 17:45   |
Chris Ring Messages: 16 Registered: July 2009 Location: Santa Barbara, CA |
Thanks. Doesn't quite meet my use case, though. By design(!) I have no idea what Modules will in my system when I compile my library.
Maybe I can, in my meta-only module's .xdt file, loop over all Modules in the system that inherit from IHeap and somehow generate a function that does what I need. (I can't find all Modules that inherit from IHeap at runtime, can I?)
Given all the <Mod>'s that inherit IHeap, I guess I can then use <Mod>_Object_first()/next() for any dynamic instances and <Mod>_Object_count()/get() for the static instances. Given all that, I could probably call this autogenerated fxn.
Any other suggestions? This isn't trivial to put together, and if there's an easier way, I'm looking for it. Thanks in advance.
Re: Iterate over all heap instances? [message #537871 is a reply to message #537815] |
Fri, 04 June 2010 00:05   |
Dave Russo Messages: 172 Registered: July 2009 |
> at runtime, can I?)
Right (and Right)
Right.
> there's an easier way, I'm looking for it. :roll: Thanks in advance.
Unfortunately, there is no better way today. Although it is possible to
create the data structures to scan all instances that are created by
modules that inherit a specific interface this would result in a fair
amount of data in systems that don't need (and can't afford) the overhead.
Obviously this can can a configurable option. Contributions are welcome.
FUDForum. Page generated in 0.02123 seconds
