Re: dependency on xpand 1.0.0 [message #538187 is a reply to message #538144] |
Sun, 06 June 2010 08:15   |
Jean-Paul de Vooght Messages: 20 Registered: April 2010 |
Fresh install problems.
I had it at one point working without the itemis site but I had accidentally started from the Eclipse for Java and couldn't quickly get the views right (problems with Ascape, etc.).
So I scrapped everything and re-started from Classic except this time I couldn't get the Xtext/Xpand dependencies right and ended up using itemis...
I am really a total newbie at this Install Manager is disappointing at times.
Here's where I'm at:
Fresh install of Classic (all installs via Install Manager)
Ascape installed OK
AGF 3D installed OK
AMP (all except sources) + Option for Ascape NOK
Cannot complete the install because one or more required items could not be found.
Software being installed: AMP AMF - Agent Modeling Framework SDK (Incubation) 0.7.0.v201005252336-17e-BlSTFKz-kQhQVjpLCFFO (org.eclipse.amp.amf.feature.group 0.7.0.v201005252336-17e-BlSTFKz-kQhQVjpLCFFO)
Missing requirement: AMF Code Generator (Incubation) 0.7.0.v201005252336 (org.eclipse.amp.amf.gen 0.7.0.v201005252336) requires 'bundle org.eclipse.xpand 1.0.0' but it could not be found
Cannot satisfy dependency:
From: AMP AMF - Agent Modeling Framework SDK (Incubation) 0.7.0.v201005252336-17e-BlSTFKz-kQhQVjpLCFFO (org.eclipse.amp.amf.feature.group 0.7.0.v201005252336-17e-BlSTFKz-kQhQVjpLCFFO)
To: org.eclipse.amp.amf.gen 0.7.0
So I have to bring in manually all other pieces listed at http://www.eclipse.org/amp/developers/building.php which include
EMF - Eclipse Modeling Framework SDK 2.5
MWE
Xpand SDK
XSD - XML Schema Definition SDK
Xtext SDK
BIRT Framework
That's where I get stuck now as the Install Manager drops the ball on me leaving findinf the right install site URLs to me...
Does this make sense or did I miss a fundamental step?
Thanks for your patience (I realize we're off the core topic here)
[Updated on: Sun, 06 June 2010 12:38] Report message to a moderator
FUDForum. Page generated in 0.02153 seconds
