[EGit] clone and push back process problems [message #537002] |
Mon, 31 May 2010 20:24  |
Kay Huber Messages: 36 Registered: July 2009 |
Member |
Hi all!
I'm using latest nightlies of both EGit (0.8.0.201005300830) and JGit (0.8.0.201005300828).
I have a "usability" (or "understanding") problem about cloning repositories and pushing back changes.
Scenario:
* In workspace A, I create a new project and use the "Share Project..." to "elevate" it to a local git managed one.
* In workspace B (on another computer), I clone the repo from Workspace A
* Working on files of workspace B, committing them to git repo on B
* Finally pushing HEAD back to workspace A
So far so good, no problems reported, everything green.
However, now, opening up workspace A is "strange":
1) All files that were "pushed" to repo connected with workspace A get a decorator "modified". However, the modification is the wrong way round: If I do a "Compare To git index", it looks as if I "undid" the changes in workspace A. Also, if I do a "commit" now on workspace A, the pushed changes from workspace B are "reverted"!
2) The only way to get everything "right" again in workspace A is by doing a "Reset..." with reset type "hard" - causing of course all changes that I did on workspace A in the meantime to be overridden!
In short: To me, it seems that the scenario "pushing into a local repo" is not really supported. Do you confirm or am I just misunderstanding something?
Thanks for any comments.
Kay
[Updated on: Mon, 31 May 2010 21:23] Report message to a moderator
Re: [EGit] clone and push back process problems [message #537399 is a reply to message #537380] |
Wed, 02 June 2010 10:22   |
Member |
Got it, thanks for the link.
Stefan Lay wrote on Wed, 02 June 2010 05:06 | But you should not push to a branch on another repository which has local
changes on that repository.
It is even not very common that you push to a branch which is checked out on
the remote.
A good practice is to have a dedicated branch as a target for pushes. You
can also create a new branches
on the remote with your push.
That's the part I have to get used to as a former SVN user: Branches are my friends and I should have many of them
All in all, I underestimated in the first place with the simple setup with two developers working on the same code where both have a workspace with their respective git repos, one created it originally and the other developer got a clone of it, it is not optional to use branches. It is a must.
In short, if I got it right now, it is crucial for both developers to work (and push) on separate branches and then merge the respective other branch into their workspace, right?
Thanks for the hints, very appreciated!
Kay
Re: [EGit] clone and push back process problems [message #581011 is a reply to message #537380] |
Member |
> I found out that the push works as designed. Please have a look at
> https://git.wiki.kernel.org/index.php/GitFaq#Why_won.27t_I_s ee_changes_in_the_remote_repo_after_.22git_push.22.3F
> which contains a detailed explanation.
> the remote.
That's the part I have to get used to as a former SVN user: Branches are my friends and I should have many of them :)
Kay
FUDForum. Page generated in 0.02283 seconds
