Home » Archived » Buckminster » Generating feature version suffixes
Generating feature version suffixes [message #536923] Mon, 31 May 2010 13:58 Go to next message
Peter Nehrer is currently offline Peter NehrerFriend
is there a way to have Buckminster generate feature versions suffixes,
basically the PDE equivalent of generateFeatureVersionSuffix=true?
I'd like the feature to get a new qualifier whenever one of its bundles
changes (i.e., gets a new revision-based qualifier) even when the
feature's own revision hasn't changed. Thanks!
--Peter
Re: Generating feature version suffixes [message #536930 is a reply to message #536923] Mon, 31 May 2010 14:20 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
There are qualifier replacement stategies available - they are described
in the documentation.
I am not sure the latest replacement stategies have been documented.
Search for open documentation issues in buckminster bugzilla.
- henrik
On 5/31/10 3:58 PM, Peter Nehrer wrote:
> --Peter
Re: Generating feature version suffixes [message #540686 is a reply to message #536930] Thu, 17 June 2010 01:06 Go to previous messageGo to next message
Henrik,
I've been trying to track this down, and it seems as though it should
already be happening. It appears independent of the qualifier replacer.
I haven't debugged it, but following the code, a feature's manifest
action, which invokes expand.feature.version from buckminster.pdetasks,
should already do the job -- use FeatureConsolidator, which in turn uses
FeatureVersionSuffixGenerator to produce the desired suffix.
Is there anything that pops into your mind as to why this wouldn't work
out of the box? Thanks again.
--Peter
> - henrik
>> Hi,
>> --Peter
Re: Generating feature version suffixes [message #540695 is a reply to message #540686] Thu, 17 June 2010 05:31 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Peter,
Did you specify the properties that declares what generator to use? I.e. something like:
qualifier.replacement.*=generator:lastRevision
generator.lastRevision.format=r{0,number,00000}
Thomas Hallgren
On 06/17/2010 03:06 AM, Peter Nehrer wrote:
> Henrik,
> --Peter
>> - henrik
>>> Hi,
>>> --Peter
Re: Generating feature version suffixes [message #540985 is a reply to message #540695] Thu, 17 June 2010 18:57 Go to previous message
Thomas,
I get the same effect with default as well as lastRevision generator.
So far I narrowed it down to this:
1. if at least one feature is included, then suffix is generated
2. if only plugins are included, then no suffix is generated
Stepping thru it a little bit, I noticed that when FeatureConsolidator
tries to get the feature's bundles (feature.getImports() in
consolidateFeatureVersion(List<ComponentIdentifier>), it gets back an
empty array. Indeed, the feature model doesn't have anything in imports;
all bundles are in plugins (so feature.getPlugins() would have worked).
Subsequently the FeatureVersionSuffixGenerator finds nothing to make a
suffix from.
Btw this probably means that the suffixes aren't getting correctly
generated if the included bundles' versions are ignored.
Is this a bug or am I missing something? Thanks.
--Peter
On 6/17/10 1:31 AM, Thomas Hallgren wrote:
> Hi Peter,
> something like:
> Regards,
> Thomas Hallgren
>> Henrik,
>> --Peter
>>> - henrik
>>>> Hi,
>>>> --Peter
Previous Topic: ERROR [0000] : Resolution attempt ended with exception: Unauthorized
Next Topic:Product IU generated to require org.eclipse.core.runtime bundles
Current Time: Mon Sep 20 06:12:55 GMT 2021
Powered by FUDForum. Page generated in 0.02603 seconds
