Home » Language IDEs » Objectteams » OTDT 0.7.0 M3 - approaching Helios(Milestone 3 is available from download.eclipse.org)
OTDT 0.7.0 M3 - approaching Helios [message #536888] Mon, 31 May 2010 11:51
Stephan Herrmann is currently offline Stephan HerrmannFriend
As Eclipse Helios is getting close to the final release this development
is closely reflected by new builds for Object Teams.
I have released 0.7.0 Milestone 3 which is compatible with Eclipse 3.6 RC2 & RC3.
This means you can download either
and add the OTDT using "Install New Software...".
If you start from the Java Package you can alternatively use the new
Market Place Client for installing the OTDT without needing to paste the
exact download URL. Just go to Help > Market Place... and search for
Object Teams.
Milestone 3 itself brings the following improvements/fixes:
310917 [compiler] [otre] implement change in semantics of precedence declaration
313804 [dom] [assist] add support for "precedence after" in DOM and quickfix
310923 [assist] Quick assist for adding/removing signatures in method bindings
314741 [compiler] violation of OTJLD 1.2.2(g) can be masked by other error
314714 [compiler] cannot compile multiple toplevel teams in the same compilation unit
311535 [debug] opening dialog for ot-launch already modifies
311503 hasRole(Object, class) getRole(Object, class) by (Sub-)type
311885 [compiler] toggling CCE in incremental compilation of nested phantom role
314039 [dom] [rewrite] more complete rewriting for method mappings
Actually bug 310917 marks a small semantic change. If you are using precedence
declarations affecting callin after method bindings, you should consult OTJLD 4.8(a).
A corresponding quick fix has been added in bug 313804.
happy downloading,
Stephan
Previous Topic:OTDT 0.7.0 M2 - this is real
Next Topic:OTDT 0.7.0 M3 - approaching Helios
Current Time: Wed Aug 12 19:36:40 GMT 2020
Powered by FUDForum. Page generated in 0.02016 seconds
