Re: p2 build fails with java1.5 but works with 1.6 [message #536869 is a reply to message #536860] |
Mon, 31 May 2010 10:40 |
Hi Nitesh,
I'm running a Buckminster headless with Java 1.5 but I'm not able to reproduce this. Would it be possible for you to
create a reproduceable example and attach it to a bugzilla? Exactly what is it that you have installed and what type of
readers are deployed in the RMAP?
- thomas
On 05/31/2010 11:57 AM, nitesh wrote:
> Hello All,
> I am having a problem while building the update site using hudson and
> buckminster. It will be a great favour if some one can guide me in
> resolving this.
> When i try to create a p2 update site and the build environment is set
> to Java 1.6 everything works fine, but as I switch it to 1.5 I get the
> following error :
> ERROR: An internal error occurred during: "Installing".
> java.lang.IllegalArgumentException: Resolution not created using
> LocalReader at
> org.eclipse.buckminster.core.reader.LocalReaderType.getFixed Location(LocalReaderType.java:50)
> at
> org.eclipse.buckminster.core.materializer.WorkspaceMateriali zer.getMaterialization(WorkspaceMaterializer.java:68)
> at
> org.eclipse.buckminster.core.materializer.WorkspaceMateriali zer.createBindSpec(WorkspaceMaterializer.java:241)
> at
> org.eclipse.buckminster.core.materializer.WorkspaceMateriali zer.performInstallAction(WorkspaceMaterializer.java:198)
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.installRecursive(AbstractMaterializer.java:164)
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.delegateAndInstallRecursive(AbstractMaterializer.java:189 )
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.installRecursive(AbstractMaterializer.java:156)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.buckminster.core.materializer.AbstractMaterializ er.performInstallActions(AbstractMaterializer.java:68)
> at
> org.eclipse.buckminster.core.materializer.InstallerJob.runIn Workspace(InstallerJob.java:52)
> at
> org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
> LocalReader
> Now the problem with our existing code is that its not been migrated yet
> for Java 1.6 and we don't want to do it just for this purpose.
> Thanks a lot in advance.
> Thanks and regards,
> Nitesh
FUDForum. Page generated in 0.02629 seconds
