Re: SWTBot tests under buckminster [message #536463 is a reply to message #536459] |
Fri, 28 May 2010 11:51 |
Ok, I did not correctly understand your question, sorry ;)
I can't help you on that topic.
Cheers
Peter Kullmann a écrit :
> Hi Mickael
> Thanks for the info. I'm aware of the swtbottestapplication and how to
> use it when launnching an eclipse instance. This is in fact what we are
> currently using to run our swtbot tests.
> The beauty of the buckminster junit, emma or launch commands is that you
> can launch a "*.launch" configuration as you would do in the IDE. When
> using buckminster headless, buckminster itself is the IDE and to launch
> SWTBot tests, one obviously has to install swtbot first.
> Now, the problem is that the launch type
> org.eclipse.swtbot.eclipse.ui.launcher.JunitLaunchConfig is included in
> the plugin org.eclipse.swtbot.eclipse.ui with dependencies to ui stuff.
> It is not usable in a headless buckminster. To solve a similar problem,
> the JDT team has separated the ui stuff from the rest.
> Peter
> Mickael Istria schrieb:
>> Hi,
>> There is already a headless test launcher. Its id is
>> org.eclipse.swtbot.eclipse.junit4.headless.swtbottestapplica tion and
>> it works in a similar way as the org.eclipse.test.uitestapplication.
>> This wiki page may be helpful: http://wiki.eclipse.org/SWTBot/Ant
>> You'll probably find a link to the blog entry that interested you from
>> the following page http://wiki.eclipse.org/SWTBot/Articles
>> HTH
>> Mickael Istria - BonitaSoft S.A.
>> http://www.bonitasoft.com/products/downloads.php
FUDForum. Page generated in 0.02595 seconds
