Home » Eclipse Projects » Eclipse Platform » creating my own builder
Re: creating my own builder [message #536417 is a reply to message #536167] |
Fri, 28 May 2010 06:31 |
Zohar Amir Messages: 419 Registered: July 2009 |
Thanks.
It seems that this document was last updated on November 23, 2004 - is it
still valid? hasn't anything changed during the last 9 years...?
My other question is how to write the builder? What libraries do I need to
use (e.g., where do I find IncrementalProjectBuilder)? How do I start a
project in eclipse to write a builder?
Zohar.
"Prakash G.R." <grprakash@gmail.com> wrote in message
news:htlg4h$52r$1@build.eclipse.org...
> On 27/05/10 12:25 PM, zohar wrote:
>> Hello all,
>> My application requires some kind of compilation before it can run (it
>> generates xml files based on the source code, and those xml files are
>> required for runtime). I thought that the best way to do this in eclipse
>> is to use a builder. First of all, I'd like to know whether this is
>> really the best option or not. Second, I'd like to know what I need to
>> do to create my own builder.
>> I'm using eclipse 3.5.2 .
>> Many thanks,
>> Zohar.
> This might help:
> http://www.eclipse.org/articles/Article-Builders/builders.ht ml
> - Prakash
> Platform UI Team, IBM
> www.eclipse-tips.com
Re: creating my own builder [message #536640 is a reply to message #536478] |
Sat, 29 May 2010 05:18 |
Thank you Paul,
I've read both, and gained a lot of new information as to the architecture
of eclipse and the way a builder is expected to work, but I think that what
I need is a "builder for dummies" (although I realize that adding builders
to the eclipse workbench is not for dummies) - where it shows me how to
create and test a simple builder (for example, one that looks for all XML
files in the project and produces corresponding XML files where all element
names are reversed or something). I'm looking for a tutorial that will guide
me from creating a new project, to the point where the builder works and
does its magic.
coming to think of it - maybe what I'm looking for is a cheat sheet for a
simple builder...
Anything of the sort...?
Zohar.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:htodlr$32l$1@build.eclipse.org...
> zohar wrote:
>> Thanks.
> Yes, this document talks about API and while it has evolved, the API from
> 2004 still works today.
>> to use (e.g., where do I find IncrementalProjectBuilder)? How do I start
>> a project in eclipse to write a builder?
> Read the article Prakash mentioned
> http://www.eclipse.org/articles/Article-Builders/builders.ht ml and track
> down the latest version of the links in http://help.eclipse.org > Platform
> Plug-in Developer Guide > Programmer's Guide > Advanced resource concepts
> where it discusses project natures and incremental builders.
> PW
> Paul Webster
> http://wiki.eclipse.org/Platform_Command_Framework
> http://wiki.eclipse.org/Command_Core_Expressions
> http://wiki.eclipse.org/Menu_Contributions
> http://wiki.eclipse.org/Menus_Extension_Mapping
> http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Current Time: Thu Apr 25 10:22:46 GMT 2024
Powered by FUDForum. Page generated in 0.03566 seconds
