Home » Archived » B3 » NoClassDefFoundError ContainerCreateException starting
NoClassDefFoundError ContainerCreateException starting [message #535994] Wed, 26 May 2010 15:23 Go to next message
Markus Oley is currently offline Markus OleyFriend
I try to call the aggregator progammatically in the following way:
Builder builder = new Builder();
builder.setAction(ActionType.BUILD);
builder.setBuildModelLocation(aggregatorFile);
The following exception is thrown and I don't know which feature contains the class:
java.lang.NoClassDefFoundError: org/eclipse/ecf/core/ContainerCreateException
at vsa.vsaeclipse.distributor.BuckminsterAdapter.createMirror(B uckminsterAdapter.java:83)
at vsa.vsaeclipse.distributor.engine.TestBuckminsterAdapter.cre ateMirror(TestBuckminsterAdapter.java:46)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.junit.internal.runners.TestMethodRunner.executeMethodBod y(TestMethodRunner.java:99)
at org.junit.internal.runners.TestMethodRunner.runUnprotected(T estMethodRunner.java:81)
at org.junit.internal.runners.BeforeAndAfterRunner.runProtected (BeforeAndAfterRunner.java:34)
at org.junit.internal.runners.TestMethodRunner.runMethod(TestMe thodRunner.java:75)
at org.junit.internal.runners.TestMethodRunner.run(TestMethodRu nner.java:45)
at org.junit.internal.runners.TestClassMethodsRunner.invokeTest Method(TestClassMethodsRunner.java:66)
at org.junit.internal.runners.TestClassMethodsRunner.run(TestCl assMethodsRunner.java:35)
at org.junit.internal.runners.TestClassRunner$1.runUnprotected( TestClassRunner.java:42)
at org.junit.internal.runners.TestClassRunner.run(TestClassRunn er.java:52)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.r un(JUnit4TestReference.java:49)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:467)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: org.eclipse.ecf.core.ContainerCreateException
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 22 more
Do you now were to find?
Best Regards
Markus
Re: NoClassDefFoundError ContainerCreateException starting [message #536376 is a reply to message #535994] Thu, 27 May 2010 21:08 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
Looks like ECF (or parts of it) is missing...
- henrik
On 5/26/10 5:23 PM, Markus Oley wrote:
> contains the class:
> ssorImpl.java:39)
> at java.lang.reflect.Method.invoke(Method.java:597)
> thodRunner.java:75)
> nner.java:45)
> Execution.java:38)
> at java.security.AccessController.doPrivileged(Native Method)
> ... 22 more
> Best Regards
> Markus
Re: NoClassDefFoundError ContainerCreateException starting [message #536503 is a reply to message #536376] Fri, 28 May 2010 14:15 Go to previous message
OK, found it, thanks,
Re: NoClassDefFoundError ContainerCreateException starting [message #608286 is a reply to message #536376] Fri, 28 May 2010 14:15 Go to previous message
Previous Topic:b3 aggregator maven mapping
Next Topic:How do I use a local eclipse-installation for aggregation
Current Time: Wed Aug 12 01:12:55 GMT 2020
Powered by FUDForum. Page generated in 0.01765 seconds
