Re: Guice Error when Xtext builder runs in Eclipse Headless [message #536282 is a reply to message #535989] |
Thu, 27 May 2010 14:37 |
Hi every body ,
i have a similar problem ; i run my eclipse in headless mode and the plugin executed contains the code :
IWorkbenchWindow window=PlatformUI.getWorkbench().getActiveWorkbenchWindow();
IWorkbenchPage page = window.getActivePage();
IEditorPart part = null;
try {
part = page.openEditor(editorInput, "com.myxtext.editor");
What is exactly the problem ?
P.S even in the headless , i gave the eclipse a workspace ..
Best Wishes.
Zakarov
Re: Guice Error when Xtext builder runs in Eclipse Headless [message #537378 is a reply to message #535989] |
Wed, 02 June 2010 08:55 |
Hi Sven ,
first sorry for my late reply ,
even if i run the plugin without launching eclipse , i give it a workspace folder as an argument,
the code showed up , is a part of my plugin code .It reads a input from the workspace , and tries to open a xtext editor and then close it.
P.S opening and closing editor allows me to set some markers and references on my xtext file.
Thank you.
Zakarov
Re: Guice Error when Xtext builder runs in Eclipse Headless [message #665022 is a reply to message #545533] |
Tue, 12 April 2011 21:11 |
Mirko Raner Messages: 125 Registered: July 2009 Location: New York City, NY |
Sven Efftinge wrote on Thu, 08 July 2010 00:47 | It looks like the error is raised, because your application doesn't
include org.eclipse.resources, which is required by the default
implementation of the builder infrastructure.
Hi Sven,
we just ran into exactly the same problem that Alex reported, i.e. we are running as a regular Eclipse workbench, not in headless mode. The full stack trace is at the end of this post. I'd just like to better understand the fix that you proposed.
The stack trace suggests that there is a problem binding the IWorkbench implementation instance in SharedModule.java, line 61:
bind(IWorkbench.class).toProvider(new Provider<IWorkbench>() {
public IWorkbench get() {
if (PlatformUI.isWorkbenchRunning())
return PlatformUI.getWorkbench();
return null;
So, it appears that the workbench is not running (or not running yet), though I have no idea how that could be because we are starting a workbench when we receive the stack trace. Our runtime includes about 15 custom plug-ins, most of them related to various Xtext grammars, which have certain dependencies between. Of the two plug-ins that seem to be in the path of this problem (com.intuit.interview.iedit.dialog.ui and com.intuit.eclipse.xtext.iunit.ui) neither one indeed declares a direct dependency on org.eclipse.core.resources (I haven't looked at transitive, re-exported dependencies yet).
I don't quite understand how to get from something that seems to be amiss with the UI set-up and workbench initialization to a missing org.eclipse.core.resources dependency. Unfortunately, I cannot immediately verify whether your suggested fix works, but I'd like to better understand how your suggestion relates to the problem.
Thanks for clarifying,
Mirko
Full stack trace below:
155 [Start Level Event Dispatcher] ERROR org.eclipse.xtext.ui.shared.internal.Activator - Error initializing org.eclipse.xtext.ui.shared:Guice provision errors:
1) null returned by binding at org.eclipse.xtext.ui.shared.internal.SharedModule.configure(SharedModule.java:61)
but org.eclipse.xtext.builder.builderState.EMFBasedPersister.workbench is not @Nullable
while locating org.eclipse.ui.IWorkbench
for field at org.eclipse.xtext.builder.builderState.EMFBasedPersister.workbench(EMFBasedPersister.java:39)
while locating org.eclipse.xtext.builder.builderState.EMFBasedPersister
while locating org.eclipse.xtext.builder.builderState.PersistableResourceDescriptionsImpl$PersistedStateProvider
for field at org.eclipse.xtext.builder.builderState.AbstractBuilderState.persister(AbstractBuilderState.java:94)
while locating org.eclipse.xtext.builder.clustering.ClusteringBuilderState
while locating org.eclipse.xtext.builder.builderState.IBuilderState
for field at org.eclipse.xtext.builder.impl.ToBeBuiltComputer.builderState(ToBeBuiltComputer.java:33)
while locating com.intuit.eclipse.xtext.iunit.ui.IUnitToBeBuiltComputer
while locating org.eclipse.xtext.builder.impl.ToBeBuiltComputer
for field at org.eclipse.xtext.builder.impl.ProjectOpenedOrClosedListener.toBeBuiltComputer(ProjectOpenedOrClosedListener.java:41)
while locating org.eclipse.xtext.builder.impl.ProjectOpenedOrClosedListener
while locating org.eclipse.core.resources.IResourceChangeListener annotated with @com.google.inject.name.Named(value=org.eclipse.xtext.builder.impl.ProjectOpenedOrClosedListener)
at org.eclipse.xtext.ui.shared.internal.ComposedResourceChangeListener.<init>(ComposedResourceChangeListener.java:24)
while locating org.eclipse.xtext.ui.shared.internal.ComposedResourceChangeListener
for field at org.eclipse.xtext.ui.shared.internal.Activator.resourceChangeListener(Activator.java:27)
while locating org.eclipse.xtext.ui.shared.internal.Activator
1 error
com.google.inject.ProvisionException: Guice provision errors:
1 error
at com.google.inject.internal.Errors.throwProvisionExceptionIfErrorsExist(Errors.java:370)
at com.google.inject.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:66)
at com.google.inject.InjectorImpl.injectMembers(InjectorImpl.java:726)
at org.eclipse.xtext.ui.shared.internal.Activator.initializeInjector(Activator.java:79)
at org.eclipse.xtext.ui.shared.internal.Activator.start(Activator.java:98)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at com.intuit.interview.iedit.dialog.ui.internal.DialogActivator.getSharedStateModule(DialogActivator.java:70)
at com.intuit.interview.iedit.dialog.ui.internal.DialogActivator.start(DialogActivator.java:39)
at com.intuit.interview.iedit.dialog.ui.DialogUIActivator.start(DialogUIActivator.java:45)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:374)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1067)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:561)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:546)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:459)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:440)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
FUDForum. Page generated in 0.03679 seconds
