Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Texo] not possible to define Embedded-id in orm
Re: [Texo] not possible to define Embedded-id in orm [message #535874 is a reply to message #535826] |
Wed, 26 May 2010 07:30 |
Originally posted by: philippe.roland.atosorigin.com
Much appreciated Martin. Keep up the good work on Texo, it's a very
handy tool and I'm greatly looking forward to future developments.
Martin Taal a écrit :
> Hi Philippe,
> This is a small mistake I made when defining the orm model. The
> embedded-id should have been defined as containment in the annotation
> model. I will repair this in the next build (this evening or tomorrow).
Re: [Texo] not possible to define Embedded-id in orm [message #535895 is a reply to message #535874] |
Wed, 26 May 2010 08:57 |
I might have spoken a touch too soon, I still can't get it to work ;)
Just in case you want to try it out with my example, here's the ecore
I'm working with:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="model"
nsURI="htpp://model.ecore" nsPrefix="model">
<eClassifiers xsi:type="ecore:EClass" name="Author">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="count"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="authorKey"
lowerBound="1"
eType="#//AuthorKey"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="AuthorKey">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="authorName"
lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//EString" iD="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="birthDate"
lowerBound="1"
http://www.eclipse.org/emf/2002/Ecore#//EDate"/>
</eClassifiers>
</ecore:EPackage>
And the annotationsmodel:
<?xml version="1.0" encoding="ASCII"?>
<annotationsmodel:AnnotatedModel xmi:version="2.0"
xmlns:annotationsmodel="http://www.eclipse.org/emf/texo/annotations/model"
xmlns:ormannotations="http://www.eclipse.org/emf/texo/orm/ormannotations">
<annotatedEPackages>
<ePackage href="model.ecore#/"/>
<annotatedEClassifiers xsi:type="annotationsmodel:AnnotatedEClass">
<eClass href="model.ecore#//Author"/>
<annotatedEStructuralFeatures
xsi:type="annotationsmodel:AnnotatedEReference">
<eReference href="model.ecore#//Author/authorKey"/>
<eReferenceAnnotations
xsi:type="ormannotations:EReferenceORMAnnotation" orderBy="">
<embeddedId name="authorKey"/>
</eReferenceAnnotations>
</annotatedEStructuralFeatures>
</annotatedEClassifiers>
<eClass href="model.ecore#//AuthorKey"/>
<eClassAnnotations xsi:type="ormannotations:EClassORMAnnotation">
<embeddable class="ecore.model.AuthorKey"/>
</eClassAnnotations>
</annotatedEPackages>
</annotationsmodel:AnnotatedModel>
(I trimmed it down to the important bits for readability, but it still
gives the same results if I just generate then change the authorKey's
ManyToOne field's annotation into an EmbeddedId and the AuthorKey Entity
annotation into an Embeddable). I see the embeddedId annotation is
there, but the resulting orm fails to pick it up (even though it does
catch the embeddable annotation):
<orm:entity-mappings
xmlns:orm="http://www.eclipse.org/eclipselink/xsds/persistence/orm"
version="2.1">
<orm:access>FIELD</orm:access>
<orm:entity class="ecore.model.Author" name="Author">
<orm:attributes>
<orm:basic name="count" optional="false"/>
<orm:many-to-one name="authorKey" optional="false"
target-entity="ecore.model.AuthorKey">
<orm:join-column/>
<orm:cascade>
<orm:cascade-persist/>
<orm:cascade-merge/>
<orm:cascade-refresh/>
</orm:cascade>
</orm:many-to-one>
</orm:attributes>
</orm:entity>
<orm:embeddable class="ecore.model.AuthorKey">
<orm:attributes>
<orm:basic name="authorName" optional="false"/>
<orm:basic name="birthDate" optional="false">
<orm:temporal>DATE</orm:temporal>
</orm:basic>
</orm:attributes>
</orm:embeddable>
</orm:entity-mappings>
Philippe Roland
PS: re-reading the .annotationsmodel, I'm wondering:
are the annotations in there written straight into the produced orm.xml
file? If so, shouldn't <embeddedId name="authorKey"/> be <embedded-id
name="authorKey"/> instead?
>> Hi Philippe,
Re: [Texo] not possible to define Embedded-id in orm [message #535932 is a reply to message #535874] |
Wed, 26 May 2010 11:56 |
Additionally, code generation appears to be broken in this build. I
filed a bugzilla over at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=314441
Looks like you've got your work cut out for you. Have fun! ^^
>> Hi Philippe,
Re: [Texo] not possible to define Embedded-id in orm [message #536035 is a reply to message #535895] |
Wed, 26 May 2010 17:52 |
Yeah, that the embedded id does not show up is another bug, I solved it locally. Will be part of the new build.
The features are indeed copied practically directly from the annotation model to the orm, but there the translation to
the correct xml tag is made.
gr. Martin
> I'm working with:
> xmlns:xmi="http://www.omg.org/XMI"
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> </ecore:EPackage>
> version="2.1">
> <orm:attributes>
> <orm:join-column/>
> <orm:cascade>
> </orm:cascade>
> </orm:many-to-one>
> </orm:attributes>
> </orm:entity>
> <orm:attributes>
> </orm:basic>
> </orm:attributes>
> </orm:embeddable>
> Cheers,
> Philippe Roland
>>> Hi Philippe,
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Texo] not possible to define Embedded-id in orm [message #622931 is a reply to message #535826] |
> Hi Philippe,
Re: [Texo] not possible to define Embedded-id in orm [message #622933 is a reply to message #535874] |
I'm working with:
lowerBound="1"
</eClassifiers>
lowerBound="1"
lowerBound="1"
</eClassifiers>
</ecore:EPackage>
version="2.1">
<orm:attributes>
<orm:join-column/>
<orm:cascade>
</orm:cascade>
</orm:many-to-one>
</orm:attributes>
</orm:entity>
<orm:attributes>
</orm:basic>
</orm:attributes>
</orm:embeddable>
Philippe Roland
>> Hi Philippe,
Re: [Texo] not possible to define Embedded-id in orm [message #622935 is a reply to message #535874] |
>> Hi Philippe,
Re: [Texo] not possible to define Embedded-id in orm [message #622941 is a reply to message #535895] |
gr. Martin
> I'm working with:
> lowerBound="1"
> </eClassifiers>
> lowerBound="1"
> lowerBound="1"
> </eClassifiers>
> </ecore:EPackage>
> version="2.1">
> <orm:attributes>
> <orm:join-column/>
> <orm:cascade>
> </orm:cascade>
> </orm:many-to-one>
> </orm:attributes>
> </orm:entity>
> <orm:attributes>
> </orm:basic>
> </orm:attributes>
> </orm:embeddable>
> Cheers,
> Philippe Roland
>>> Hi Philippe,
The Netherlands
Current Time: Thu Apr 25 07:55:45 GMT 2024
Powered by FUDForum. Page generated in 0.04297 seconds
