Importing EPF models [message #54001] |
Wed, 08 October 2008 16:15 |
Originally posted by: ralf.buschermoehle.informatik.uni-oldenburg.de
first of all great tool :)
I would like to import epf models ... or more concrete the ecore part -
is this easily possible? I looked into the sources and extracted
diagram.ecore & uma.ecore. Would it be possible to import parts of a
method library?
Greetings,
Ralf
Re: Importing EPF models [message #54468 is a reply to message #54024] |
Wed, 12 November 2008 09:56 |
Hi Andrea,
thanks for the answer. But I did not mean epf export/epf import rather
then epf export/my tool import.
I must admit that this was not really obvious concerning the thread ... :(
Nevertheless I managed to import epf models. But why does epf seperate
an uma xmi and a uma (without xmi)?
Is it planned to combine epf with the uml2 project to fulfill the
process behavior?
Greetings,
Ralf
Andrea wrote:
> Before importing you have to export what you need. Example: Someone has
> elaborated a plug-in with some method library you would like to take a
> look. The method plug-in should be exported using the menu File ->
> Export, then the file generated could be imported by you in your EPF.
> I hope this can help you,
> Regards
> Andrea
FUDForum. Page generated in 0.02253 seconds
