Home » Archived » Buckminster » ClassCastException while aggregating site
ClassCastException while aggregating site [message #535681] Tue, 25 May 2010 08:54 Go to next message
Jesper Eskilson is currently offline Jesper EskilsonFriend
I'm getting a weird error when trying to aggregate a site. The .b3aggr
file used worked fine last week or so.
> aggregate-site:
> [delete] Deleting directory /home/jesperes/tmpws/helios.site
> [echo] Aggregating /home/jesperes/dev/tooticki/core/ide/eclipse/features/com.ia r.hubble.releng/helios.b3aggr into /home/jesperes/tmpws/helios.site
> [java] Loading all repositories
> [java] Starting generation of composite repository
> [java] Adding child meta-data repository http://seupp-s-hemulen.ad.iar.com/ide_irp_storage/eclipse/up date-sites/cdt-master-7.0.0-I201003141308
> [java] Adding child meta-data repository http://ftp.ing.umu.se/mirror/eclipse/releases/helios
> [java] Done. Took 0 seconds
> [java] Starting generation of verification feature
> [java] Starting generation of categories
> [java] Starting planner verification
> [java] Verifying config win32,win32,x86...
> [java] Done. Took 2 minutes 47 seconds
> [java] Build failed! Exception was org.eclipse.core.runtime.CoreException: java.lang.ClassCastException: org.eclipse.equinox.internal.p2.metadata.InstallableUnit cannot be cast to org.eclipse.equinox.p2.metadata.IInstallableUnitPatch
> [java] Caused by: java.lang.ClassCastException: org.eclipse.equinox.internal.p2.metadata.InstallableUnit cannot be cast to org.eclipse.equinox.p2.metadata.IInstallableUnitPatch
> [java] java.lang.ClassCastException: org.eclipse.equinox.internal.p2.metadata.InstallableUnit cannot be cast to org.eclipse.equinox.p2.metadata.IInstallableUnitPatch
> [java] Caused by:
Should I report this as a bug in Buckminster?
/Jesper
Re: ClassCastException while aggregating site [message #535682 is a reply to message #535681] Tue, 25 May 2010 09:02 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Jesper,
I think this was reported yesterday. You can track it here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=314108
Thomas Hallgren
>> aggregate-site:
>> [echo] Aggregating
>> [java] Caused by:
Re: ClassCastException while aggregating site [message #536433 is a reply to message #535682] Fri, 28 May 2010 08:49 Go to previous messageGo to next message
On 2010-05-25 11:02, Thomas Hallgren wrote:
> Hi Jesper,
Is anyone working on this? This is preventing us from building against
recent Helios milestones.
/Jesper
Re: ClassCastException while aggregating site [message #536817 is a reply to message #535682] Mon, 31 May 2010 07:05 Go to previous messageGo to next message
On 05/25/2010 11:02 AM, Thomas Hallgren wrote:
> Hi Jesper,
I saw that this was just fixed in revision 1035. When will that appear
on http://download.eclipse.org/modeling/emft/b3/updates-3.6?
Jesper Eskilson
Developer
IAR Systems
Re: ClassCastException while aggregating site [message #536818 is a reply to message #536817] Mon, 31 May 2010 07:22 Go to previous messageGo to next message
The fix concerns publishing, i.e. how Helios is created, not how it's read. But since the culprit patch has been
removed, I don't think you need the fix in order to aggregate Helios now.
In any case, I plan to publish a new version of the aggregator later today.
- thomas
>> Hi Jesper,
Re: ClassCastException while aggregating site [message #536866 is a reply to message #536818] Mon, 31 May 2010 10:34 Go to previous message
> read. But since the culprit patch has been removed, I don't think you
I still get the error when I try to aggregate Helios now, even when I
aggregate directly from eclipse.org. Do I need to wait for the next
Helios RC?
Jesper Eskilson
Developer
IAR Systems
Previous Topic:Strange errors with Resource Map editor
Next Topic:"One or more certificates rejected" during create.product action
Current Time: Sat Sep 18 16:59:42 GMT 2021
Powered by FUDForum. Page generated in 0.01449 seconds
