Home » Archived » Maven Integration (M2E) » No "SCM URL"s in "Checkout as Maven Project from SCM"(eclipse maven m2eclipse subversion)
No "SCM URL"s in "Checkout as Maven Project from SCM" [message #535475] Mon, 24 May 2010 00:07 Go to next message
Steven Dahlin is currently offline Steven DahlinFriend
Galileo is installed with m2eclipse and subclipse. When attempting to "Checkout a Maven Project from SCM" for the drop down list "SCM URL" the box has no options listed. I tried entering "scm:svn:svn://<svn repo url>/producta" (a valid location) on the second drop down I get simply get a message in the maven console: "SCM provider is not available for scm:svn:<svn repo url>/producta"
I have also tried http though I am using the svn protocol to no effect as well. Does anyone have any suggestions as to what could cause this and specifically how to fix it?
Re: No "SCM URL"s in "Checkout as Maven Project from SCM" [message #535481 is a reply to message #535475] Mon, 24 May 2010 01:07 Go to previous messageGo to next message
Eugene Kuleshov is currently offline Eugene KuleshovFriend
You need to install one of the SCM providers for m2eclipse. There is 3
providers available for svn support - a generic Maven SCM providers, one
for Subclipse and another one for Subversive. See some docs at
https://docs.sonatype.org/display/M2ECLIPSE/Home
regards,
Eugene
> Thanks
Re: No "SCM URL"s in "Checkout as Maven Project from SCM" [message #535483 is a reply to message #535481] Mon, 24 May 2010 02:13 Go to previous messageGo to next message
You indicated: "You need to install one of the SCM providers for m2eclipse". I have both m2eclipse and subeclipse installed and when I check both sites for installing more plugins for eclipse it indicates everything is installed. Is there some other plugin from some other site to install. I checked the docs you talked about but in the " https://docs.sonatype.org/display/M2ECLIPSE/Integration+with +Subclipse" doc it does not point to any install plugin.
Re: No "SCM URL"s in "Checkout as Maven Project from SCM" [message #535487 is a reply to message #535483] Mon, 24 May 2010 03:11 Go to previous message
The m2eclipse consist of multiple features. Some of them are optional
(including all SCM handlers) and you have to install them from the
extras update site. See
http://m2eclipse.sonatype.org/installing-m2eclipse.html
regards,
Eugene
> Thanks
Previous Topic:adding a maven project to a repository
Next Topic:Galileo - M2Eclipse Subversive Integration
Current Time: Fri Apr 16 20:28:16 GMT 2021
Powered by FUDForum. Page generated in 0.02058 seconds
