Re: compile 32bit on 64bit [message #537437 is a reply to message #537393] |
Wed, 02 June 2010 12:56 |
Axel Mueller Messages: 1973 Registered: July 2009 |
For Windows crossompilation you need the mingw package. And I recommend installing the crosscompilation feature of the Ecipse CDT plugin .
Quote: | For SDL libs i wanted to include a different lib (32bit) location but apparently I forgot something alike libconfig or so. I'm stuck there for now. Simply copying from the 32bit linux doesn't work.
You have to install the 32Bit version of the libs. Download the 32Bit package (deb file). And then install it from the command line:
sudo dpkg -i --force-all <package_i386.deb>
the force-all option is necessayr to install 32Bit package on a 64bit system.
If you need more libs you can use the package "getlibs" (http://ubuntuforums.org/showthread.php?t=474790)
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
[Updated on: Wed, 02 June 2010 12:59] Report message to a moderator
Re: compile 32bit on 64bit [message #537475 is a reply to message #537437] |
Wed, 02 June 2010 15:05 |
Michael Mising name Messages: 103 Registered: July 2009 |
I've simply selected them at install of 10.04.
Now that's the error I get:
g++ -Lmedia/openSuse-/usr/lib/ -m32 -shared -o"lin.xpl" ./main.o -lSDL -lSDL_mixer -lalut -lSDL_image -lGL -lGLU
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../libSDL.so when searching for -lSDL
/usr/bin/ld: skipping incompatible /usr/lib/gcc/x86_64-linux-gnu/4.4.3/../../../libSDL.a when searching for -lSDL
/usr/bin/ld: skipping incompatible /usr/lib/libSDL.so when searching for -lSDL
/usr/bin/ld: skipping incompatible /usr/lib/libSDL.a when searching for -lSDL
/usr/bin/ld: cannot find -lSDL
collect2: ld returned 1 exit status
make: *** [lin.xpl] Fehler 1
Can I copy the libs from suse to f.ex. /usr/libsSuse32 and then simply run ldconfig from that directory? What about the win & osx libs?
[Updated on: Wed, 02 June 2010 15:24] Report message to a moderator
FUDForum. Page generated in 0.02236 seconds
