Home » Modeling » GMF (Graphical Modeling Framework) » org.eclipse.gmf not accessible from CVS(how to access to taipan examples?)
org.eclipse.gmf not accessible from CVS [message #535322] Sat, 22 May 2010 09:55 Go to next message
Gicquel  is currently offline Gicquel Friend
Hi everyone.
My problem is that i can't access to org.eclipse.gmf through CVS as described in GMF tutorial.
I created a repository to dev.eclipse.org/modeling as described and it worked perfectly, but when I expand HEAD, there is no org.eclipse.gmf.
I try to check on the web-CVS navigator here : http://dev.eclipse.org/viewcvs/index.cgi/?root=Modeling_Proj ect and there seem to be no org.eclipse.gmf neither.
I am new to eclipse and CVS so maybe I have done something wrong or maybe the org.eclipse.gmf has been suppressed?
Thank you for help or advices!
Re: org.eclipse.gmf not accessible from CVS [message #535690 is a reply to message #535322] Tue, 25 May 2010 09:37 Go to previous message
Aurélien Pupier is currently offline Aurélien PupierFriend
the gmf project is currently in restructuring phase. The location may have change.
You may take a look here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=310208
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Previous Topic:Can't delete a Component of diagram that I've create
Next Topic:Keep Selected Object(node) active until user select the other Object(node in the GMF diagram editor
Current Time: Fri Jun 21 20:32:18 GMT 2024
Powered by FUDForum. Page generated in 0.04086 seconds
