Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Running a installed acceleo bundle from a Java main method
[Acceleo] Running a installed acceleo bundle from a Java main method [message #535080] Fri, 21 May 2010 09:15 Go to next message
Fabien Giquel is currently offline Fabien GiquelFriend
here is a context of launching an acceleo module which does not work. I would like to know if it is an expected limit or if it is a bug :
- Helios M7 with acceleo bundles.
- installed an acceleo module X in plugins directory.
- creating in the workspace a simple Java project (not a plugin project) and adding to the classpath the emf and acceleo jars.
- writing a Java class with a main method which invokes the acceleo module X main Java class for generation (calling the doGenerate() method)
Running the java class as 'Java application' results in an error : "invalid relative pathName : ... .emtl" (more details in the thread http://www.eclipse.org/forums/index.php?t=msg&th=168568& amp;start=0&)
The problem is that the .emtl file is located in a .jar (the module X installed bundle) and acceleo generated code expects to find it unzipped (calling URI.createFileURI(..)).
Of course calling the same way from a plugin (eclipse context) works fine.
Thanks in advance.
Fabien GIQUEL
R&D Engineer
Mia-Software
rue Nina Simone
44000 NANTES
Re: [Acceleo] Running a installed acceleo bundle from a Java main method [message #535101 is a reply to message #535080] Fri, 21 May 2010 09:51 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------020509020606070703080305
Hi Fabien,
This is a known limitation we're currently trying to break. I built a
little more than an hour ago a nightly that should fix the issue, but
have yet to confirm the fix. If you wish to help in the verification (or
check that it works in your context), the nightly can be retrieved from
http://modeling.eclipse.org/modeling/m2t/acceleo/downloads/d rops/3.0.0/N201005210354/m2t-acceleo-SDK-incubation-N2010052 10354.zip
Laurent Goubet
Obeo
Fabien Giquel wrote:
> http://www.eclipse.org/forums/index.php?t=msg&th=168568& amp;start=0&) The
> Thanks in advance.
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020509020606070703080305--
Previous Topic:[XPAND] Dynamic Instance
Next Topic:Using JET on WSDL and XSD
Current Time: Mon Feb 17 12:07:10 GMT 2020
Powered by FUDForum. Page generated in 0.08630 seconds
