Re: Deploying an OpenVXML on Apache Tomcat [message #535268 is a reply to message #535261] |
Fri, 21 May 2010 18:57 |
Ok. Here are the details:
i) I downloaded the installer 3 days back ( which again means it would be the latest version available).
ii) I am using Ubuntu 9.04 Jaunty as OS.
iii) however the java -version shows 1.6.0_0 , while installing this OpenVXML, I also downloaded jre1.6.0_20 and installed it in /opt/ and changed the file OpenVXMLGalileo-3.0.25/eclipse/eclipse.ini to:
launcher.XXMaxPermSize
256m
-vm
/opt/jre1.6.0_20/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
In which case I guess the java version you are asking me is this one.
Apurv
Re: Deploying an OpenVXML on Apache Tomcat [message #535275 is a reply to message #535268] |
Fri, 21 May 2010 19:20 |
Randy Childers Messages: 121 Registered: July 2009 |
Hi Apurv--
It sounds like you've done everything right. Ubuntu 9.04 wasn't a platform we explicitly tested for, but we're going to take a look at that now. In the meantime, I'd like to see the .war file you generated. Please contact me directly at
randy at openmethods dot com
so we can work out a hand-off.
Thanks, and my apologies for the bump in the road--
Randy
[Updated on: Fri, 21 May 2010 19:22] Report message to a moderator
Re: Deploying an OpenVXML on Apache Tomcat [message #579204 is a reply to message #535261] |
256m
-vm
-vmargs
-Xms40m
-Xmx512m
Apurv
FUDForum. Page generated in 0.04426 seconds
