Home » Archived » Buckminster » The project cannot be built until its prerequisite org.eclipse.ui is built.
Re: The project cannot be built until its prerequisite org.eclipse.ui is built. [message #534788 is a reply to message #534778] |
Thu, 20 May 2010 10:56 |
Maxi Messages: 9 Registered: May 2010 |
I tried
buckminster -data c:\temp\tutorial build
there are a lot of errors like
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu: build.properties does not exist
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 11: Package 'com.ibm.icu.lang' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 12: Package 'com.ibm.icu.math' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 13: Package 'com.ibm.icu.text' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 14: Package 'com.ibm.icu.util' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 15: Package 'com.ibm.icu.impl' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 16: Package 'com.ibm.icu.impl.data' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 17: Package 'com.ibm.icu.impl.data.icudt40b' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 18: Package 'com.ibm.icu.impl.data.icudt40b.brkitr' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 19: Package 'com.ibm.icu.impl.data.icudt40b.coll' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 20: Package 'com.ibm.icu.impl.data.icudt40b.rbnf' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 21: Package 'com.ibm.icu.impl.data.icudt40b.translit' does not exist in this plug-in
Warning: file C:\TEMP\tutorial\plugins\com.ibm.icu\META-INF\MANIFEST.MF, line 23: The 'Eclipse-LazyStart' header is deprecated, use 'Bundle-ActivationPolicy'
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 7: The type 'org.eclipse.core.internal.databinding.obs
ervable.Activator' is not on the plug-in classpath
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 14: Package 'org.eclipse.core.databinding.observable.set
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 15: Package 'org.eclipse.core.databinding.observable.val
ue' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 16: Package 'org.eclipse.core.databinding.util' does not
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 17: Package 'org.eclipse.core.internal.databinding.ident
ity' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 19: Package 'org.eclipse.core.internal.databinding.obser
vable' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 20: Package 'org.eclipse.core.internal.databinding.obser
vable.masterdetail' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 10: Package 'org.eclipse.core.databinding.observable' do
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 11: Package 'org.eclipse.core.databinding.observable.lis
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 12: Package 'org.eclipse.core.databinding.observable.map
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observable\META-INF\MANIFEST.MF, line 13: Package 'org.eclipse.core.databinding.observable.mas
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.property: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 47: "schema/viewActions.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 48: "schema/views.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 49: "schema/workingSets.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 50: "schema/browserSupport.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 51: "schema/internalTweaklets.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 52: "schema/installationPages.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\META-INF\MANIFEST.MF, line 7: The type 'org.eclipse.ui.internal.UIPlugin' is not on the plug-in classpath
Error: file C:\TEMP\tutorial\plugins\org.eclipse.ui\META-INF\MANIFEST.MF, line 10: Package 'org.eclipse.ui.internal' does not exist in this plug-in
and
buckminster -data c:\temp\tutorial perform org.eclipse.buckminster.tutorial.mailapp.product.feature#site.p2 INFO: [end org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#source.feature.jar]
INFO: [start org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#copy.features]
INFO: [end org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#copy.features]
INFO: [start org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#copy.plugins]
INFO: [end org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#copy.plugins]
INFO: [start org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#site.p2]
INFO: [end org.eclipse.buckminster.tutorial.mailapp.product.feature:eclipse.feature$1.0.0#site.p2]
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.property\META-INF\MANIFEST.MF, line 18: Package 'org.eclipse.core.internal.databinding.propert
y.value' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.beans\META-INF\MANIFEST.MF, line 9: Package 'org.eclipse.core.internal.databinding.beans' does
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.core.databinding\META-INF\MANIFEST.MF, line 7: The type 'org.eclipse.core.internal.databinding.Activator' is
Error: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.ds\META-INF\MANIFEST.MF, line 10: Package 'org.eclipse.equinox.internal.ds.storage.file' does not exist
in this plug-in
Warning: file C:\TEMP\tutorial\features\org.eclipse.equinox.executable\feature.xml, line 202: Plug-in reference 'org.eclipse.equinox.launcher.gtk.linux.s390' ca
nnot be resolved
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.directorywatcher: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.extensionlocation: Build path specifies execution environment J2SE-1.4. There are no JREs installe
d in the workspace that are strictly compatible with this environment.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.metadata.generator: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.reconciler.dropins: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.repository.tools: build.properties does not exist
Error: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.repository.tools\META-INF\MANIFEST.MF, line 10: Package 'org.eclipse.equinox.p2.internal.repository.
tools.tasks' does not exist in this plug-in
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.util: build.properties does not exist
Error: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.util\META-INF\MANIFEST.MF, line 15: Package 'org.eclipse.equinox.internal.util.impl.tpt' does not exist
in this plug-in
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.help: build.properties does not exist
Error: file C:\TEMP\tutorial\plugins\org.eclipse.help\META-INF\MANIFEST.MF, line 42: Package 'org.eclipse.help.internal.util' does not exist in this plug-in
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.swt: build.properties does not exist
Error: file C:\TEMP\tutorial\plugins\org.eclipse.swt\META-INF\MANIFEST.MF, line 11: Package 'org.eclipse.swt.dnd' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.jface\META-INF\MANIFEST.MF, line 36: Package 'org.eclipse.jface.wizard.images' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.jface.databinding\META-INF\MANIFEST.MF, line 19: Package 'org.eclipse.jface.internal.databinding.viewers' does
Error: file C:\TEMP\tutorial\plugins\org.eclipse.jface.databinding\META-INF\MANIFEST.MF, line 20: Package 'org.eclipse.jface.databinding.util' does not exist in
this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.ui.workbench\META-INF\MANIFEST.MF, line 16: Package 'org.eclipse.ui.application' does not exist in this plug-in
Error: file C:\TEMP\tutorial\plugins\org.eclipse.ui.workbench\META-INF\MANIFEST.MF, line 95: Package 'org.eclipse.ui.wizards' does not exist in this plug-in
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.ui\plugin.xml, line 22: "schema/editorActions.exsd" does not reference a schema file.
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.security.ui: build.properties does not exist
Error: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.security.ui\META-INF\MANIFEST.MF, line 16: Package 'org.eclipse.equinox.internal.security.ui.wizard' do
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.ui: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.ui\META-INF\MANIFEST.MF, line 48: The 'Eclipse-LazyStart' header is deprecated, use 'Bundle-Activa
tionPolicy'
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.ui.sdk: Build path specifies execution environment J2SE-1.4. There are no JREs installed in the wo
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.ui.sdk: build.properties does not exist
Warning: file C:\TEMP\tutorial\plugins\org.eclipse.equinox.p2.ui.sdk\META-INF\MANIFEST.MF, line 37: The 'Eclipse-LazyStart' header is deprecated, use 'Bundle-Ac
tivationPolicy'
Error: file C:\TEMP\tutorial\plugins\org.eclipse.buckminster.tutorial.mailapp\src\org\eclipse\buckminster\tutorial\mailapp\View.java, line 72: GridData cannot b
e resolved
Error: file C:\TEMP\tutorial\plugins\org.eclipse.buckminster.tutorial.mailapp\src\org\eclipse\buckminster\tutorial\mailapp\Perspective.java, line 19: IFolderLay
out cannot be resolved to a type
Error: file C:\TEMP\tutorial\plugins\org.eclipse.buckminster.tutorial.mailapp\src\org\eclipse\buckminster\tutorial\mailapp\OpenViewAction.java, line 32: IWorkbe
nchWindow cannot be resolved to a type
Error: file C:\TEMP\tutorial\plugins\org.eclipse.buckminster.tutorial.mailapp\src\org\eclipse\buckminster\tutorial\mailapp\MessagePopupAction.java, line 23: IWo
rkbenchWindow cannot be resolved to a type
Error: file C:\TEMP\tutorial\plugins\org.eclipse.buckminster.tutorial.mailapp\src\org\eclipse\buckminster\tutorial\mailapp\ApplicationActionBarAdvisor.java, lin
e 82: IWorkbenchAction cannot be resolved to a type
Error: file C:\TEMP\tutorial\plugins\org.eclipse.buckminster.tutorial.mailapp\src\org\eclipse\buckminster\tutorial\mailapp\Activator.java, line 59: The method i
mageDescriptorFromPlugin(String, String) is undefined for the type Activator
Warning: file C:\TEMP\tutorial\features\org.eclipse.rcp\feature.xml, line 531: Plug-in reference 'org.eclipse.equinox.launcher.cocoa.macosx' cannot be resolved
Found 23 errorsand 23 warnings
Build failed!
any ideas?
Rainer
[Updated on: Thu, 20 May 2010 10:59] Report message to a moderator
Re: The project cannot be built until its prerequisite org.eclipse.ui is built. [message #534795 is a reply to message #534788] |
Thu, 20 May 2010 11:17 |
Hi Rainer,
Are you importing the com.ibm.icu bundle into your workspace? I don't understand why that should be built from source.
The source you have seems be corrupt. Does it build in your IDE?
- thomas
On 05/20/2010 12:56 PM, Rainer wrote:
> Hi
> I tried
> not exist
> plug-in
> in this plug-in
> this plug-in
> this plug-in
> Warning: file
> C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observ able:
> Warning: file
> C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.observ able\META-INF\MANIFEST.MF,
> Error: file
> Error: file
> Error: file
> Error: file
> Error: file
> Error: file
> Error: file
> Error: file
> Error: file
> Error: file
> Warning: file
> C:\TEMP\tutorial\plugins\org.eclipse.core.databinding.proper ty:
Re: The project cannot be built until its prerequisite org.eclipse.ui is built. [message #629981 is a reply to message #534850] |
Thu, 30 September 2010 08:33 |
Hello Thomas, hello Maxi,
Sorry for "kidnapping" this thread. However I have the same problem.
I'm working with Buckminster 3.5 (org.eclipse.buckminster.core_1.1.350.r11409.jar). Seems to be the latest for Buckminster 3.5.
I also get spurious "The project cannot be built until its prerequisite ...". Up to now I solved it by reopening the workspace with (head-full?) eclipse 3.5,cleaning the project explicitely and restarting buckminster. This is very tedious, because I get several of these messages until buckminster finally succeeds.
I'm just tried your advice with the "build"-command. However as I suspected that produced various "package ... does not exist in this plug-in" messages.
The reason for this seems to be that I configured to resolve only the binaries of the imported plugins. Eclipse/Buckminster seems to have a problem to import these binaries correctly into the workspace.
I tried to simulate this problem with my local eclipse installation, but was not able to provoke this problem.
Any ideas?
Current Time: Sat Apr 20 01:37:55 GMT 2024
Powered by FUDForum. Page generated in 0.05048 seconds
