Home » Eclipse Projects » OSEE » Application server starts with errors
Application server starts with errors [message #534670] Wed, 19 May 2010 15:41 Go to next message
i tried to start the application server (oseeAppServer_postgres_0.9.1)
with the following :
java -Dosee.log.default=INFO -Declipse.ignoreApp=true -Dorg.osgi.service.http.port=8089 -Dosgi.compatibility.bootdelegation=true -Xms40m -Xmx512m -Dosee.db.cid=postgresqlLocalhost -Dosee.application.server.data=/home/michael/Eclipse/osee_da ta -Dequinox.ds.debug=true -jar org.eclipse.osgi.jar -console
Then i got the following console output:
osgi> Wed May 19 21:30:51 CEST 2010 org.eclipse.osee.framework.database.internal.InternalActivat or
INFO org.eclipse.osee.framework.database.internal.DbConnectionInf ormation bind (70)
binding org.eclipse.osee.demo.db.connection.DemoDbConnectionInfo@67071c84
INFO org.eclipse.osee.framework.database.internal.parser.DbConfig Parser getAllDbServices (50)
in getAllDbServices 3
INFO org.eclipse.osee.framework.database.internal.DbConnectionInf ormation bind (74)
osee.microdoc: jdbc:postgresql://78.46.71.230:5432/OSEE : user=osee
postgresqlLocalhost: jdbc:postgresql://localhost:5432/OSEE : user=osee
derby: jdbc:derby://127.0.0.1:1621/DerbyDatabase; : user=osee
binding org.eclipse.osee.framework.database.internal.UriDbConnection Info @44ea5461
Adding: org.eclipse.osee.framework.core.server.internal.ServerDataba seProvider @37b994de
Wed May 19 21:30:51 CEST 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.internal.ServerTaskSc heduler addServerTask (41)
Adding task: Clean up join tables
Wed May 19 21:30:52 CEST 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.OseeServerProperties getOseeApplicationServerData (69)
Application Server Data: [/home/michael/Eclipse/osee_data]
Registered servlet '/osee/manager'
Registered servlet '/osee/resource'
Registered servlet '/GET.ARTIFACT'
Registered servlet '/osee/artifact'
Registered servlet '/index'
Registered servlet '/osee/branch/exchange'
Registered servlet '/osee/branch'
Registered servlet '/osee/search'
Registered servlet '/osee/search/tagger'
Registered servlet '/osee/server/lookup'
Registered servlet '/osee/session'
Registered servlet '/osee/client/loopback'
Registered servlet '/osee/install/info'
Registered servlet '/osee/cache'
Registered servlet '/osee/model'
Wed May 19 21:30:54 CEST 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore getOseeVersionsByServerId (195)
Server lookup table is not initialized
Wed May 19 21:30:54 CEST 2010 org.eclipse.osee.framework.database.internal.InternalActivat or
SCHWERWIEGEND org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl runBatchUpdate (158)
This is the nested exception
org.postgresql.util.PSQLException: FEHLER: Relation »osee_server_lookup« existiert nicht
at org.postgresql.core.v3.QueryExecutorImpl.receiveErrorRespons e(QueryExecutorImpl.java:1608)
at org.postgresql.core.v3.QueryExecutorImpl.processResults(Quer yExecutorImpl.java:1343)
at org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecut orImpl.java:343)
at org.postgresql.jdbc2.AbstractJdbc2Statement.executeBatch(Abs tractJdbc2Statement.java:2668)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.runBatchUpdate(OseeDatabaseServiceImpl.java:14 9)
at org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl.runBatchUpdate(OseeDatabaseServiceImpl.java:17 2)
at org.eclipse.osee.framework.database.core.ConnectionHandler.r unBatchUpdate(ConnectionHandler.java:81)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore.deregisterWithDb(ApplicationServerDataStore.j ava:74)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.writeToDataStore(InternalOseeServerInfo.java:114)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.updateRegistration(InternalOseeServerInfo.java:12 2)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager.executeLookupRegistration(ApplicationServerMana ger.java:87)
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager$1.run(ApplicationServerManager.java:56)
at java.util.TimerThread.mainLoop(Timer.java:534)
at java.util.TimerThread.run(Timer.java:484)
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore deregisterWithDb (77)
Server lookup table not initialized
at org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore.registerWithDb(ApplicationServerDataStore.jav a:94)
at org.eclipse.osee.framework.core.server.internal.InternalOsee ServerInfo.writeToDataStore(InternalOseeServerInfo.java:115)
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverDataStore registerWithDb (97)
Wed May 19 21:30:56 CEST 2010 org.eclipse.osee.framework.search.engine.internal.SearchEngi neTagger
INFO org.eclipse.osee.framework.search.engine.internal.StartUpRun nable run (45)
Tagging on Server Startup was not run.
With that it is not possible to initialize the database.
I have configured the postgresql database like describes in the "Getting Stated" guide.
Any ideas?
Michael
Re: Application server starts with errors [message #534909 is a reply to message #534670] Thu, 20 May 2010 11:44 Go to previous messageGo to next message
Hello Michael.
Did you try running the database initialisation script after the point you have shown?
Whilst you have had exceptions, it looks like the application server has reached the point where it may still be able to accept a connection and initialise the tables, which would then remove the exceptions the next time it is started.
All the best,
Mark
Re: Application server starts with errors [message #535228 is a reply to message #534909] Fri, 21 May 2010 12:28 Go to previous messageGo to next message
Hello Mark.
Yes - i've tried.
I used:
./eclipse -nosplash -application org.eclipse.osee.framework.database.init.configClient -console -vmargs -XX:MaxPermSize=256m -Xmx512m -Dosee.application.server=http://localhost:8089
An got:
osgi> Adding: org.eclipse.osee.framework.core.client.internal.ClientDataba seProvider @151ff451
OSEE Application Server Validation [PASSED]
Removing: org.eclipse.osee.framework.core.client.internal.ClientDataba seProvider @151ff451
And o nthe server side:
Fri May 21 18:20:08 CEST 2010 org.eclipse.osee.framework.manager.servlet.MasterServletActi vator
SCHWERWIEGEND org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet doPost (95)
Error processing session request [ org.eclipse.equinox.http.servlet.internal.HttpServletRequest Adaptor @7041a12f]
org.eclipse.osee.framework.core.exception.OseeWrappedExcepti on:
at org.eclipse.osee.framework.core.data.BaseExchangeData.loadfr omXml(BaseExchangeData.java:45)
at org.eclipse.osee.framework.core.data.OseeCredential.fromXml( OseeCredential.java:70)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.createSession(SessionManagementServlet.java:111)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.doPost(SessionManagementServlet.java:86)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.eclipse.osee.framework.core.server.internal.InternalOsee HttpServlet.service(InternalOseeHttpServlet.java:80)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:502)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:380)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapp er.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:535)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:880)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:748)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 219)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:520)
Caused by: java.lang.IllegalStateException: Method getLocalName() cannot be called for START_DOCUMENT event.
at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl. getLocalName(XMLStreamReaderImpl.java:330)
at org.eclipse.osee.framework.jdk.core.type.PropertyStoreWriter $XMLReader.process(PropertyStoreWriter.java:158)
at org.eclipse.osee.framework.jdk.core.type.PropertyStoreWriter $XMLReader.load(PropertyStoreWriter.java:147)
at org.eclipse.osee.framework.jdk.core.type.PropertyStoreWriter .load(PropertyStoreWriter.java:48)
at org.eclipse.osee.framework.jdk.core.type.PropertyStoreWriter .load(PropertyStoreWriter.java:52)
at org.eclipse.osee.framework.core.data.BaseExchangeData.loadfr omXml(BaseExchangeData.java:43)
... 24 more
2010-05-21 18:20:08.307::WARN: ERROR: /osee/session
java.lang.IllegalStateException: STREAM
at org.mortbay.jetty.Response.getWriter(Response.java:595)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.doPost(SessionManagementServlet.java:97)
Michael
Re: Application server starts with errors [message #535238 is a reply to message #535228] Fri, 21 May 2010 13:07 Go to previous messageGo to next message
Hello Michael,
You appear to now be getting the same error as Kumar in this thread: http://www.eclipse.org/forums/index.php?t=msg&th=162878& amp;start=0&
I am wondering whether this could be due to some internationalisation issue. I am suspecting (no evidence to back this up) that Kumar may have some non-English settings in Windows and I see that you are configured in such a way that some of the error messages are in German.
Nirmal and I don't get the problem, so this is not a general OSEE issue, it is something down to individual installations.
All the best,
Mark
Re: Application server starts with errors [message #535879 is a reply to message #535238] Wed, 26 May 2010 03:55 Go to previous messageGo to next message
Hello Mark,
i have setup a new system in a virtual machine (Virtual Box) and install a new System with "Great Britain" regional settings. Bit the problem remains. Any other ideas?
When i have more time i will try to check out and build the server on my machine.
My installed system was not a Wondows. I use Kubuntu 10.04LTS on an AMD 64bit.
Could this be a problem?
Michael
Re: Application server starts with errors [message #539946 is a reply to message #535879] Mon, 14 June 2010 07:16 Go to previous messageGo to next message
Dear Michael,
OSEE 0.9.4 is now available. Because the database is not compatible with 0.9.1, I have needed to initialise a 0.9.4 database to allow import.
When the app server is started and before the init has bee run, repeated exceptions of the following form occur. This is normal because the database has no tables in it yet:
SEVERE org.eclipse.osee.framework.database.internal.core.OseeDataba seServiceImpl runBatchUpdate (155)
org.postgresql.util.PSQLException: ERROR: relation "osee_server_lookup" does not exist
I then ran the init (option 1, to allow a test to be done on the client before using option 0 to import my real database). At the end of the init, on the server side, the following two exceptions were reported. However, stopping and restarting the application server yielded a functioning OSEE.
SEVERE org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet doPost (96)
Error processing session request [ org.eclipse.equinox.http.servlet.internal.HttpServletRequest Adaptor @1015495]
org.eclipse.osee.framework.core.exception.OseeInvalidAuthent icationProtocolException: Invalid protocol []
at org.eclipse.osee.framework.core.server.internal.Authenticati onManager.authenticate(AuthenticationManager.java:56)
at org.eclipse.osee.framework.core.server.internal.SessionManag er.createSession(SessionManager.java:144)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.createSession(SessionManagementServlet.java:113)
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.doPost(SessionManagementServlet.java:87)
at org.eclipse.osee.framework.core.server.internal.InternalOsee HttpServlet.service(InternalOseeHttpServlet.java:79)
2010-06-14 12:12:57.703::WARN: ERROR: /osee/session
at org.eclipse.osee.framework.manager.servlet.SessionManagement Servlet.doPost(SessionManagementServlet.java:98)
I suggest you try downloading 0.9.4 to see whether you are then able to run.
All the best,
Mark
Re: Application server starts with errors [message #544496 is a reply to message #534670] Fri, 02 July 2010 17:51 Go to previous messageGo to next message
Dear Michael,
Because of the issues that you and other Linux users have been experiencing, I decided to do a test using my home computer which runs Mandriva 2010.
Please verify the steps you have been through against the following, which I have confirmed works up to the point of successfully creating a demo database.
Install Eclipse 3.5.2
Download the 0.9.4 client from the OSEE downloads page
Choose it as an archive in the Eclipse update manager and install it
This will install the OSEE client and everything else it needs EXCEPT the PostgreSQL driver
Download the PostgreSQL driver from the OSEE downloads page
Download the 0.9.4 server from the OSEE downloads page and unzip it
Unzip the PostgreSQL driver
Copy the two files from the plugins folder in the PostgreSQL driver to the plugins folder of the server
Create an empty PostgreSQL database per the instructions on the OSEE web site
Start the application server, ignoring any messages about tables not existing
In the directory containing your OSEE eclipse, execute the following:
eclipse -application org.eclipse.osee.framework.database.init.configClient -vmargs -Xmx512m -Dosee.log.default=INFO -Dosee.application.server=http://localhost:8089 -Dosee.authentication.protocol=trustAll -Dosee.prompt.on.db.init=false -Dosee.choice.on.db.init="OSEE Demo Database"
This is proven to create a functional demo database under both Windows and Linux (tested on Mandriva 2010)
I have not yet connected an OSEE client to this database under Linux, but this is the output you should then get on next starting the server:
[mark@quiet org.eclipse.osee.server_postgresql_0.9.4_incubation]$ ./runPostgresqlLocal.sh
osgi> Fri Jul 02 22:47:53 BST 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
Application Server Data: [/home/mark]
Registered servlet '/osee/unsubscribe'
Registered servlet '/osee/ats'
Fri Jul 02 22:47:56 BST 2010 org.eclipse.osee.framework.search.engine.internal.SearchEngi neTagger
INFO org.eclipse.osee.framework.search.engine.internal.StartUpRun nable run (42)
Fri Jul 02 22:47:58 BST 2010 org.eclipse.osee.framework.database.internal.Activator
INFO org.eclipse.osee.framework.database.internal.core.OseeConnec tionPoolImpl getConnection (77)
DbConnection: [jdbc:postgresql://localhost:5432/OSEE] - [1]
DbConnection: [jdbc:postgresql://localhost:5432/OSEE] - [2]
Fri Jul 02 22:47:58 BST 2010 org.eclipse.osee.framework.core.server.CoreServerActivator
INFO org.eclipse.osee.framework.core.server.internal.ApplicationS erverManager executeLookupRegistration (92)
Application Server: [f694be1eb779113f05692b171146a61d] registered.
All the best,
Mark
Re: Application server starts with errors [message #576715 is a reply to message #534670] Thu, 20 May 2010 11:44 Go to previous messageGo to next message
Hello Michael.
All the best,
Mark
Re: Application server starts with errors [message #576740 is a reply to message #534909] Fri, 21 May 2010 12:28 Go to previous messageGo to next message
Hello Mark.
Yes - i've tried.
I used:
An got:
osgi> Adding: mailto: org.eclipse.osee.framework.core.client.internal.ClientDataba seProvider @151ff451
Removing: mailto: org.eclipse.osee.framework.core.client.internal.ClientDataba seProvider @151ff451
Error processing session request [mailto: org.eclipse.equinox.http.servlet.internal.HttpServletRequest Adaptor @7041a12f]
... 24 more
Michael
Re: Application server starts with errors [message #576753 is a reply to message #535228] Fri, 21 May 2010 13:07 Go to previous messageGo to next message
Hello Michael,
All the best,
Mark
Re: Application server starts with errors [message #576783 is a reply to message #576753] Wed, 26 May 2010 03:55 Go to previous messageGo to next message
Hello Mark,
Michael
Re: Application server starts with errors [message #576890 is a reply to message #576783] Mon, 14 June 2010 07:16 Go to previous messageGo to next message
Dear Michael,
Error processing session request [mailto: org.eclipse.equinox.http.servlet.internal.HttpServletRequest Adaptor @1015495]
All the best,
Mark
Re: Application server starts with errors [message #577028 is a reply to message #534670] Fri, 02 July 2010 17:51 Go to previous message
Dear Michael,
[mailto:mark@quiet org.eclipse.osee.server_postgresql_0.9.4_incubation]$ ./runPostgresqlLocal.sh
All the best,
Mark
Previous Topic:Ubuntu (Unix) Postgresql. OSEE Server Not starting?
Next Topic:Attention Linux users - 0.9.4 is proven to work under Mandriva 2010
Current Time: Sat Jun 21 17:34:32 EDT 2025
Powered by FUDForum. Page generated in 0.06822 seconds
