Home » Eclipse Projects » Virgo » Build Virgo
Re: Build Virgo [message #534546 is a reply to message #534350] |
Wed, 19 May 2010 13:50 |
I need to have a go at recreating this, I can see that you are in the Kernel repo, could you tell me what ant command you are calling?
Thanks.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: Build Virgo [message #535215 is a reply to message #534636] |
Fri, 21 May 2010 15:22 |
1st, I've learnt I have to manually subscribe to forum posts, I don't automatically notified of new posts, so sorry for the delay.
2nd, it's nothing obvious so I need to go and run the build which I will do next week. Hopefully I'll be able to see what is happening then. If it's an issue with our stuff I'll ask you to raise a bug and we will get on it.
Thanks for getting back to us,
Chris
Re: Build Virgo [message #536540 is a reply to message #534350] |
Fri, 28 May 2010 15:49 |
I have tried this several times now and have it building fine but the tests are failing to start in the userigion. The cause will be Windows specific as it works on other platforms. We need to raise a JIRA issue to address this issue, I would be very grateful if you could do this and then it will get the proper attention. In the mean time you can try dm Server 2.0.2, it is functionally equivalent (http://www.springsource.org/dmserver).
Virgo Bugzilla
Chris
[Updated on: Fri, 28 May 2010 15:50] Report message to a moderator
Re: Build Virgo [message #537078 is a reply to message #536672] |
Tue, 01 June 2010 09:14 |
It's good to hear it's all working for you. I've tried downloading the file a few times and every time it looks like a copy of some HTML source from the Eclipse forums. I take it this isn't what you meant to attach.
Chris.
Re: Build Virgo [message #537109 is a reply to message #537106] |
Tue, 01 June 2010 11:15 |
Thanks for that. The 'waiting for reference' messages coming out at the start are simply the result of the machine it's running on being a little slow, just warnings so nothing to worry about. Our dev machines are quite fast so we could of set the limits a little to eager. I think if you are getting this on production equipment it would be worth raising a bug getting us to move the limits back a little.
Thanks, Chris.
Re: Build Virgo [message #537251 is a reply to message #537109] |
Tue, 01 June 2010 16:49 |
Veselin Kovacevic Messages: 12 Registered: April 2010 |
Hi Chris,
It's log from my desktop win machine (Win XP, Pentium 4, 2GB) where besides kernel at same time running STS, Tomcat, Firefox, Outlook and several applications and corporate policy services (PF usage 1.5 GB approx.). So, when I turned off some of these apps, 'waiting for reference' messages disappeared.
Log from WinXP (PF usage 750 MB)
[2010-06-01 14:09:54.334] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0001I Kernel starting.
[2010-06-01 14:10:02.412] kernel-dm-11 org.eclipse.virgo.medic.eventlog.default SH0001I Kernel ssh shell available on port 2401.
[2010-06-01 14:10:02.583] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0002I Kernel started.
[2010-06-01 14:10:02.740] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:03.990] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:04.443] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:04.583] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:04.708] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:04.771] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.302] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:10.318] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:10.318] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:10.333] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.349] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:10.349] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:10.412] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:10.427] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:10.458] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:10.474] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 14:10:11.505] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 14:10:11.505] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:11.537] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.552] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 14:10:11.583] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.583] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.724] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 14:10:11.740] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 14:10:11.755] Thread-2 org.eclipse.virgo.medic.eventlog.default UR0001I User region ready.
In addition, I have checked on Linux production machine (RH Enterprise 5, 4GB, dual-core).
Kernel started twice faster than on Win machine without 'waiting' messages.
I used same win build (of course after converted bin scripts in unix format).
Log from RHE 5
[2010-06-01 17:44:33.689] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0001I Kernel starting.
[2010-06-01 17:44:38.537] kernel-dm-11 org.eclipse.virgo.medic.eventlog.default SH0001I Kernel ssh shell available on port 2401.
[2010-06-01 17:44:38.636] startup-tracker org.eclipse.virgo.medic.eventlog.default KE0002I Kernel started.
[2010-06-01 17:44:38.750] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:38.843] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:38.879] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:38.900] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:38.918] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:38.934] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0000I Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.877] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.882] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:39.886] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:39.891] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.896] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:39.901] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0001I Installed plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:39.932] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:39.941] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.951] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.core' version '1.2.1'.
[2010-06-01 17:44:39.951] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:40.388] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.extender' version '1.2.1'.
[2010-06-01 17:44:40.394] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:40.404] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.springframework.osgi.io' version '1.2.1'.
[2010-06-01 17:44:40.404] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.424] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.427] system-artifacts org.eclipse.virgo.medic.eventlog.default DE0004I Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.557] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '2.1.0.BUILD-20100529174554'.
[2010-06-01 17:44:40.563] start-signalling-1 org.eclipse.virgo.medic.eventlog.default DE0005I Started plan 'org.eclipse.virgo.kernel.userregion.springdm' version '2.1.0'.
[2010-06-01 17:44:40.570] Thread-2 org.eclipse.virgo.medic.eventlog.default UR0001I User region ready.
Veso
Re: Build Virgo [message #537365 is a reply to message #537251] |
Wed, 02 June 2010 08:25 |
Thanks for letting us know. It's good to know they go away on that hardware, they really should. This is useful to know.
Chris.
Re: Build Virgo [message #577073 is a reply to message #534350] |
Thanks.
Re: Build Virgo [message #577120 is a reply to message #534636] |
Chris
Re: Build Virgo [message #577179 is a reply to message #534350] |
https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advan ced;order=Importance;classification=RT;product=Virgo
Chris
Re: Build Virgo [message #579092 is a reply to message #579040] |
Chris.
Re: Build Virgo [message #579138 is a reply to message #579123] |
Thanks, Chris.
Re: Build Virgo [message #579159 is a reply to message #537109] |
Hi Chris,
Log from RHE 5
Veso
Re: Build Virgo [message #579180 is a reply to message #537251] |
Chris.
Current Time: Fri Apr 19 20:04:43 GMT 2024
Powered by FUDForum. Page generated in 0.04880 seconds
