Home » Eclipse Projects » Standard Widget Toolkit (SWT) » [INFO]When you dont get response to your posts.(It only means two things 1.It has no answer,2.Its answer is too obvious.)
icon10.gif  [INFO]When you dont get response to your posts. [message #534324] Tue, 18 May 2010 16:27 Go to next message
Vijay RajFriend
No Message Body
why, mr. Anderson, why, why do you persist?
Because I Choose To.
Vijay
[Updated on: Tue, 18 May 2010 16:28]
Report message to a moderator
Re: [INFO]When you dont get response to your posts. [message #534719 is a reply to message #534324] Thu, 20 May 2010 06:44 Go to previous message
Praveen  is currently offline Praveen Friend
Member
vijay wrote:
Well, thats a good question! In those cases, I believe it is good to
re-post the same question on the same thread. That would be helpful for
grabbing our attention and understanding your importance.
If you are quite sure that would be a bug in SWT, then you can raise a
bug request..or, if your request can serve as an enhancement to the
product, then you can raise a enhancement request against SWT.
Previous Topic:Can I find what CTabItem my Control is in?
Next Topic:Change text to read only
Current Time: Tue Feb 25 06:04:04 GMT 2020
Powered by FUDForum. Page generated in 0.02034 seconds
