Home » Archived » M2M (model-to-model transformation) » while
while [message #534162] Tue, 18 May 2010 05:17 Go to next message
how I can express in ocl:
while (w different from empty sequence) do?
thanks
Re: while [message #534190 is a reply to message #534162] Tue, 18 May 2010 06:26 Go to previous messageGo to next message
The "for" statement enables to define iterative imperative computations. A "for" statement has to conform to the following syntax:
for(iterator in collection) {
statements
The "for" statement defines an iteration variable (iterator) that will iterate over the different elements of the reference collection. For each of these elements, the sequence of statements contained by the "for" statement will be executed.
The following example, also related to the MMPerson metamodel (see Appendix B) illustrates the use of the "for" imperative statement:
for(p in MMPerson!Person.allInstances()) {
if(p.gender = #male)
thisModule.men->including(aPerson);
else
thisModule.women->including(aPerson);
accordingly u should do some thing like this
for(i in K) -- where k is ur sequence
if i <> sequence{}
then
else
end if
Re: while [message #534191 is a reply to message #534190] Tue, 18 May 2010 06:28 Go to previous messageGo to next message
I liked this tutorial
hope u too
http://sosym.dcs.kcl.ac.uk/events/mtip05/submissions/jouault _kurtev__transforming_models_with_atl.pdf
[Updated on: Tue, 18 May 2010 06:30] by Moderator
Re: while [message #534308 is a reply to message #534162] Tue, 18 May 2010 11:39 Go to previous messageGo to next message
collection->iterate(e; result: Type=<expression> | <expression-with-e-and-result>)
Re: while [message #534791 is a reply to message #534308] Thu, 20 May 2010 07:06 Go to previous messageGo to next message
thanks
but,what means <expression-with-e-and-result>?
Re: while [message #534937 is a reply to message #534162] Thu, 20 May 2010 13:28 Go to previous message
The variable element is the iterator variable. The resulting value is accumulated in the variable result, which is also called the accumulator. The accumulator gets an initial value, given by the expression after the equal sign. None of the parameters is optional
The result of the iterate operation is a value obtained by iterating over all elements in a collection. For each successive element in the source collection, the body expression (<expression-with-element-and-result>) is calculated using the previous value of the result variable. A simple example of the iterate operation is given by the following expression, which results in the sum of the elements of a set of integers:
Set{1,2,3}->iterate( i: Integer, sum: Integer = 0 | sum + i )
Previous Topic:[QVTO] Inline Object Creation
Next Topic:1..* transformation in QVT
Current Time: Thu Jul 17 22:01:15 EDT 2025
Powered by FUDForum. Page generated in 0.32478 seconds
