Home » Archived » Buckminster » .qualifier "ignored" in plugins
.qualifier "ignored" in plugins [message #533897] Mon, 17 May 2010 08:39 Go to next message
I have added .qualifier suffix to all my plugins and features versions, in order to automatic bundle version update (for update site).
But unfortunately it doesn't work as I expected; during every build process only features version are updated. Plugins versions during every build are exactly the same as in build when .qualifier was used for first time.
What am I doing wrong?
Or maybe it's a clever/better solution for automatic bundle version update?
Re: .qualifier "ignored" in plugins [message #533918 is a reply to message #533897] Mon, 17 May 2010 09:24 Go to previous messageGo to next message
What qualifier generator are you using? What type of SCM?
- thomas
On 05/17/2010 02:39 PM, Maciej Oledzki wrote:
> first time.
Re: .qualifier "ignored" in plugins [message #533950 is a reply to message #533918] Mon, 17 May 2010 10:34 Go to previous messageGo to next message
Thomas Hallgren wrote on Mon, 17 May 2010 09:24
What qualifier generator are you using? What type of SCM?>
I didn't specify any generator, and all projects are fetched from SVN by Hudson, not Buckminster.
Re: .qualifier "ignored" in plugins [message #534005 is a reply to message #533950] Mon, 17 May 2010 13:03 Go to previous messageGo to next message
What kind of qualifier replacement do you want?
- thomas
Re: .qualifier "ignored" in plugins [message #534007 is a reply to message #534005] Mon, 17 May 2010 13:22 Go to previous messageGo to next message
The perfect solution:
plugin: qualifier is only changed when there is a change in plugin
feature: qualifier is only change when there is a change in one of it's plugins
Sufficient solutions:
plugins, features: qualifier is changed during each build
BTW: I add
-D qualifier.replacement.*=generator:buildTimestamp -D generator.buildTimestamp.format=yyyyMMdd-HHmm
to my perform command, but it doesn't have influence on qualifier values, they still looks like: 201005171539, or
[Updated on: Mon, 17 May 2010 13:27] by Moderator
Re: .qualifier "ignored" in plugins [message #534015 is a reply to message #534007] Mon, 17 May 2010 13:45 Go to previous messageGo to next message
With SVN it is possible to use a qualifier generator that uses the
repository revision number (this is what is used for buckminster itself
btw).
The various generators, and how they are used are explained in the
documentation. There are lots of different ways to use them, formats
etc. Take a look, and please ask again if something is unclear.
- henrik
> it's plugins
- henrik
Re: .qualifier "ignored" in plugins [message #534206 is a reply to message #534015] Tue, 18 May 2010 07:24 Go to previous messageGo to next message
I've read chapter about qualifier replacements once again, and unfortunately it didn't help.
1. I set qualifier replacement to buildTimestamp:
-Dqualifier.replacement.*=generator:buildTimestamp
2. Custom format was also set:
-Dgenerator.buildTimestamp.format=yyyyMMdd-HHmm
3. Build process was performed, everything end successfully, booth plugin and features have correct qualifier replacement.
4. Some changes are made to one plugin, and another build was performed. But in this case, only features versions contain current build time stamp. All plugins have exactly the same timestamp as in previous build.
What should I do, for automatically update plugin versions during all builds?
Re: .qualifier "ignored" in plugins [message #534210 is a reply to message #534206] Tue, 18 May 2010 07:39 Go to previous messageGo to next message
Hi Maciej,
Did you clean out the previous build?
- thomas
> -Dqualifier.replacement.*=generator:buildTimestamp 2. Custom format was
> also set:
> builds?
Re: .qualifier "ignored" in plugins [message #534211 is a reply to message #534210] Tue, 18 May 2010 07:44 Go to previous messageGo to next message
No, I have noticed during my tests that removing buckminster.output and buckminster.temp solved my problem, but I think that its not clean solution.
So cleaning is a only solution to my problem?
Re: .qualifier "ignored" in plugins [message #534234 is a reply to message #534211] Tue, 18 May 2010 08:17 Go to previous messageGo to next message
> solution.
There are two philosophies that collide here.
1. Don't bump the version unless somethings changed.
2. Create a new version for every build.
Buckminster is very much in favor of the former since the latter will force your users to update each an every bundle
every time you post a new build. So yes, if you want to enforce that, then you do need to clean out the builds.
HTH,
- thomas
Re: .qualifier "ignored" in plugins [message #534461 is a reply to message #534234] Wed, 19 May 2010 05:38 Go to previous message
OK, thanks for explanations.
Previous Topic:com.ibm.icu not resolved in buckminster headless
Next Topic:merge new build into p2 repository?
Current Time: Fri Jun 20 22:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.05843 seconds
