Saving Diagram as Image is clipped if negative co-ordinates. How to solve this? [message #533437] |
Thu, 13 May 2010 20:58 |
h1055071 Messages: 335 Registered: July 2009 |
The problem is that if any of the diagram's child figures have a
negative x,y, location (for example, x = -100, y = -100) this portion is
not saved to the image. It seems that the figure only saves to image
from origin (0, 0).
I'm using a ScalableFreeformRootEditPart, and a FreeformLayer with
FreeformLayout for my diagram's main edit part.
This is how I save the diagram as an image:
ScalableFreeformRootEditPart rootEditPart =
(ScalableFreeformRootEditPart)diagramViewer.getRootEditPart( );
IFigure figure = rootEditPart.getLayer(LayerConstants.PRINTABLE_LAYERS);
Rectangle rectangle = figure.getBounds();
Image image = new Image(Display.getDefault(), rectangle.width,
rectangle.height);
GC gc = new GC(image);
SWTGraphics graphics = new SWTGraphics(gc);
figure.paint(graphics);
ImageLoader loader = new ImageLoader();
loader.data = new ImageData[]{ image.getImageData() };
loader.save(file, SWT.IMAGE_PNG);
Any ideas? Thanks.
Phil
Re: Saving Diagram as Image is clipped if negative co-ordinates. How to solve this? [message #533508 is a reply to message #533507] |
Fri, 14 May 2010 10:39 |
On 14/05/2010 11:21, Phillipus wrote:
> On 14/05/2010 10:25, vijay wrote:
>> This is not possible,
>> because if the image is clipped then the figure on the canvas also
>> should be clipped.
>> because both are being drawn using GC,only difference being canvas or
>> image.
>> can you provide a snippet to proove your point.
> Hi, thanks for help!
> I can't really provide more of a "snippet" than the following that I
> have implemented:
> My Editor extends GraphicalEditorWithFlyoutPalette.
> My Graphical Viewer's Root EditPart is a ScalableFreeformRootEditPart:
> ScalableFreeformRootEditPart rootEditPart = new
> ScalableFreeformRootEditPart();
> getGraphicalViewer().setRootEditPart(rootEditPart);
> My domain model's main EditPart extends AbstractGraphicalEditPart and
> creates a main layer as follows:
> protected IFigure createFigure() {
> FreeformLayer figure = new FreeformLayer();
> figure.setLayoutManager(new FreeformLayout());
> return figure;
> This ensures that I can place child figures anywhere on the diagram
> including in negative co-ordinates. If I do this, the scroll bars allow
> me to see all of the diagram.
> My "Save as Image" action is basically:
> (ScalableFreeformRootEditPart)graphicalViewer.getRootEditPar t();
> rectangle.height);
> loader.data = new ImageData[] { image.getImageData() };
I found the answer. I need to add the following line:
graphics.translate(rectangle.x * -1, rectangle.y * -1);
So it is now:
rectangle.height);
FUDForum. Page generated in 0.03854 seconds
