Home » Modeling » OCL » Re: EAnnotations and their contents
Re: EAnnotations and their contents [message #533243] |
Wed, 12 May 2010 16:54 |
Ed Merks Messages: 33113 Registered: July 2009 |
--------------030208070002070708040800
Philipp,
OCL is doing some pretty funky stuff computing a name when the name is
null. Even worse it the caches the result of that computation so that
the feature behaves as if it's been set explicitly to that computed name
and therefore doesn't change later when the things it's computed from
have changed.
public String getName() {
if (name == null) {
StringBuffer myName = new StringBuffer();
switch (getKind()) {
case SET_LITERAL :
myName.append(SetType.SINGLETON_NAME);
break;
case ORDERED_SET_LITERAL :
myName.append(OrderedSetType.SINGLETON_NAME);
break;
case BAG_LITERAL :
myName.append(BagType.SINGLETON_NAME);
break;
case SEQUENCE_LITERAL :
myName.append(SequenceType.SINGLETON_NAME);
break;
default :
myName
.append(org.eclipse.ocl.types.CollectionType.SINGLETON_NAME) ;
break;
myName.append('(');
EClassifier elementType = getElementType();
String elementTypeName;
if (elementType != null) {
elementTypeName = elementType.getName();
} else {
elementTypeName = ""; //$NON-NLS-1$
myName.append(elementTypeName);
myName.append(')');
name = myName.toString();
return name;
Changing it to this
set2.getLoadOptions().put(XMLResource.OPTION_DEFER_IDREF_RES OLUTION,
Boolean.TRUE);
Resource actual = set2.getResource(URI.createFileURI(new
File("test.ecore").getAbsolutePath()), true);
I.e., deferring ID resolution so that getName isn't called until after
the resource is fully loaded avoids this problem.
Why aren't you giving this thing a name? That seems to be the root
problem...
Philipp Berger wrote:
> Hey Ed,
> sorry for my confusing error discriptions.
> Here is the Code which throws an unexpected
> UnresolvedReferenceException on reloading the resource.
> I figured out that this is caused by the ocl BagType itself, in
> contrast to the normal Ecore DataType, the BagType get not enumeratet
> if there is no name.
> So for DataType without name the URI will be (...contents/.0), but for
> an BagType an unresolvable URI like (.../Bag(ElementType)) is created.
> The actual Element has no name, as consequence the link is not
> resolvable.
> My Quickfix was to ask the executed EcoreUtil.getUri(type), actual I
> don't no why as side effect the BagType get a name but it works.
> Best regards,
> Phil
> ResourceSet set = new ResourceSetImpl();
> * Create resource
> set.getResourceFactoryRegistry().getExtensionToFactoryMap(). put( "*",
> new EcoreResourceFactoryImpl());
> Resource r = set.createResource(URI.createFileURI(new
> File("test.ecore").getAbsolutePath()));
> EPackage myPkg = EcoreFactory.eINSTANCE.createEPackage();
> myPkg.setName("p");
> r.getContents().add(myPkg);
> EClass myClass = EcoreFactory.eINSTANCE.createEClass();
> myClass.setName("class2");
> EAttribute attr = EcoreFactory.eINSTANCE.createEAttribute();
> attr.setName("link");
> myClass.getEStructuralFeatures().add(attr);
> myPkg.getEClassifiers().add(myClass);
> EAnnotation annotation =
> EcoreFactory.eINSTANCE.createEAnnotation();
> annotation.setSource("mySource");
> BagType bag =
> org.eclipse.ocl.ecore.EcoreFactory.eINSTANCE.createBagType() ;
> bag.setInstanceClassName("org.eclipse.ocl.util.Bag");
> bag.setElementType(myClass);
> attr.setEType(bag);
> * add Bag to EAnnotation
> annotation.getContents().add(bag);
> myPkg.getEAnnotations().add(annotation);
> try {
> r.save(null);
> } catch (IOException e) {
> // TODO Auto-generated catch block
> e.printStackTrace();
> ResourceSet set2 = new ResourceSetImpl();
> * Unable to load resource UnResolvedReference Error
> set2.getResourceFactoryRegistry().getExtensionToFactoryMap() .put( "*",
> return null;
> Am 12.05.2010 12:12, schrieb Ed Merks:
>> Philipp,
>> Please create a test case that demonstrates the problem you're actually
>> having and then I can have a look at that.
>>> Hey Ed,
>>> thanks for the hint, but but my problem is not that the Annotations
>>> are not present after generating (sure this problem will be the next
>>> step). My Problem is more about loading an .ecore File, manipulating
>>> the Annotations of some classes and have links between the
>>> AnnotationsContents of differnent classes (or between classes and
>>> package annotations).
>>> Beste Regards and thanks for your fast reply,
>>> Phil
>>> Am 06.05.2010 11:10, schrieb Ed Merks:
>>>> Phil,
>>>> If you look at generated packages, you'll see that the contents of
>>>> annotations aren't present in the generated instances. If you use the
>>>> GenPackage's Initialize by Loading property, you should end up with
>>>> generated packages that contain the full annotation structure.
>>>>> Hey guys,
>>>>> I currently playing around with EAnnotations and their content
>>>>> reference.
>>>>> So my scenario:
>>>>> I have elements A, B and C. A and B are contained in the same
>>>>> Package,
>>>>> but C is contained in an Annotation from A.
>>>>> My problem:
>>>>> When B has a reference to C, I get an UnresolvedReferenceException.
>>>>> that one is not able to resolve '//{sourceOfTheAnnotation}/C'.
>>>>> Has anyone an idea how to make this stuff work?
>>>>> Best Regards,
>>>>> Phil
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Philipp,<br>
<br>
null.
Ed Merks
Re: EAnnotations and their contents [message #533776 is a reply to message #533243] |
Sun, 16 May 2010 21:34 |
Ed Willink Messages: 7655 Registered: July 2009 |
MDT/OCL https://bugs.eclipse.org/bugs/show_bug.cgi?id=313048 raised.
Ed Willink
On 12/05/2010 17:54, Ed Merks wrote:
> Philipp,
> have changed.
> if (name == null) {
> case SET_LITERAL :
> break;
> break;
> case BAG_LITERAL :
> break;
> break;
> default :
> myName
> ..append(org.eclipse.ocl.types.CollectionType.SINGLETON_NAME );
> break;
> myName.append('(');
> } else {
> myName.append(')');
> return name;
> Changing it to this
> Boolean.TRUE);
> problem...
>> Hey Ed,
>> resolvable.
>> Best regards,
>> Phil
>> * Create resource
>> myPkg.setName("p");
>> BagType bag =
>> attr.setEType(bag);
>> try {
>> r.save(null);
>> return null;
>>> Philipp,
>>>> Hey Ed,
>>>> Phil
>>>>> Phil,
>>>>>> Hey guys,
>>>>>> reference.
>>>>>> So my scenario:
>>>>>> Package,
>>>>>> My problem:
>>>>>> Best Regards,
>>>>>> Phil
Current Time: Thu Mar 28 17:39:39 GMT 2024
Powered by FUDForum. Page generated in 0.05236 seconds
