Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Help! Problem about SWT example under Widnows 7
Help! Problem about SWT example under Widnows 7 [message #532865] Tue, 11 May 2010 12:21 Go to next message
Diddy  is currently offline Diddy Friend
Hi, everyone!
I have problem with running SWT example under Windows 7 professional, when I show SWT example in following operation: Window->ShowView->Other..., I got following error log:
"Category org.eclipse.swt.examples.category not found for view org.eclipse.swt.examples.ole.win32.browserView. This view added to 'Other' category."
Is there any idea to fix it? I'm sure everything is fine under Windows XP.
Re: Help! Problem about SWT example under Widnows 7 [message #533354 is a reply to message #532865] Thu, 13 May 2010 13:45 Go to previous messageGo to next message
Grant Gayed is currently offline Grant GayedFriend
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=307155 . I think there
was a period of time where the examples were not being built correctly, and
also be aware that the means of installing them have changed in 3.6. If you
follow the steps in the linked bug report with eclipse 3.6M7 or newer then
it should work for you.
Grant
"Diddy" <iowoi10801@gmail.com> wrote in message
news:hsbi4g$a8q$1@build.eclipse.org...
> Hi, everyone!
category."
Re: Help! Problem about SWT example under Widnows 7 [message #702961 is a reply to message #533354] Wed, 27 July 2011 01:52 Go to previous message
Previous Topic:Change the font size when resizing windows
Next Topic:Adding actions to properties view
Current Time: Thu Mar 04 01:47:02 GMT 2021
Powered by FUDForum. Page generated in 0.02319 seconds
