http session question [message #532573] |
Mon, 10 May 2010 13:31 |
Niels Lippke Messages: 71 Registered: December 2009 |
Member |
I always thought, that the SessionStore has a 1:1 relationship to the
underlying http session. But when I hit F5 to reload the page, the
SessionStore fires a SessionStoreEvent to signal, that the session is about
to be destroyed, and after the reload the http session id is still the
same...?
Which led me assume, that the http session survived the reload (as
excepted), but the SessionStore did not.
How do I get to know, when a http session is invalidated?
Niels
Re: http session question [message #532753 is a reply to message #532573] |
Tue, 11 May 2010 06:52 |
Rüdiger Herrmann Messages: 581 Registered: July 2009 |
Niels,
your assumptions are right so far: for each http session there is one
SessionStore.
Reloading the page in the browser leads to the SessionStore being
re-created. The HttpSession will stay the same. It can only be
invalidated by the servlet engine.
Leaving the HttpSession untouched in these cases gives you the
possibility to store attributes (e.g. login credentials) in the
HttpSession that will "survive" the restart of the SessionStore.
In order to get notified about the end of an http session, use an
HttpSessionBindingListener. See the HttpSession#setAttribute JavaDoc for
more information.
HTH
Rüdiger
Rüdiger Herrmann
http://eclipsesource.com
On 10.05.2010 15:31, Niels Lippke wrote:
> about to be destroyed, and after the reload the http session id is still
> the same...?
> Regards,
> Niels
Re: http session question [message #532763 is a reply to message #532753] |
Tue, 11 May 2010 07:32 |
Member |
Thanks a lot Rüdiger!
Niels
"Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
news:hsaur3$hcq$1@build.eclipse.org...
> Niels,
> SessionStore.
> re-created. The HttpSession will stay the same. It can only be invalidated
> Leaving the HttpSession untouched in these cases gives you the possibility
> to store attributes (e.g. login credentials) in the HttpSession that will
> more information.
> HTH
> Rüdiger
> Rüdiger Herrmann
>> Hi,
>> the same...?
>> Regards,
>> Niels
Re: http session question [message #534145 is a reply to message #534091] |
Tue, 18 May 2010 08:20 |
lsq wrote:
> Seems that in M7, when I refresh the window, only session store is
> unbounded and there is no change on http session object?
As Rüdiger stated already in this thread:
Ralf
FUDForum. Page generated in 0.03441 seconds
