Home » Archived » Buckminster » finding out dependencies when building a product
finding out dependencies when building a product [message #532213] Fri, 07 May 2010 14:34 Go to next message
Jesper Eskilson is currently offline Jesper EskilsonFriend
I'm trying to build a product out of our toolchain and debugger plugins,
so that we can deliver a branded IDE. To include the relevant parts of
the Eclipse workbench we need I have a "platform"-feature which includes
all the plugins we need to include.
The problem is how to figure out which plugins we need to include.
Currently I'm adding plugins one at a time and then creating the product
to see what the director application complains about. Lather, rinse, repeat.
Although this seems to work, isn't there an easier way to do this?
/Jesper
Re: finding out dependencies when building a product [message #532220 is a reply to message #532213] Fri, 07 May 2010 14:52 Go to previous messageGo to next message
Johannes Utzig is currently offline Johannes UtzigFriend
Hi Jesper,
you can do the following:
1. create a target platform definition to compile against (that's
usually a good idea), but don't include anything from your local
installation, but use for example a number of update sites.
2. create a feature that contains your stuff
3. for the headless build start by activating the target platform defintion
4. resolve your query
5. build a p2 site from your feature
6. invoke the create product action
In the ant file that starts the p2 director you can specify a list of
update sites and a list of IUs, not just one. For the repositories you
add the output of the site.p2 action (e.g. ${sp:repository}) and all
other repositories that you used in your target definition file.
As IUs you pass the product/feature you built as well as any additional
IUs that you want in your final product.
The p2 director will then install all listed IUs and resolves
dependencies against all listed repositories.
In production environments it makes sense of course to mirror all
external update sites in the intranet to not depend on external
resources. The b3 aggregator (former Buckminster Aggregator) is just
great for this task.
Hope that helps and best regards,
Johannes
Re: finding out dependencies when building a product [message #532231 is a reply to message #532220] Fri, 07 May 2010 15:27 Go to previous messageGo to next message
On 2010-05-07 16:52, Johannes Utzig wrote:
> Hi Jesper,
Yes, this is more or less how I am doing it now.
Ok. This sounds like a more sane method.
Yes, this is on my todo-list already. :-)
> Johannes
Thanks a lot!
/Jesper
Re: finding out dependencies when building a product [message #532246 is a reply to message #532220] Fri, 07 May 2010 16:31 Go to previous messageGo to next message
> Hi Jesper,
How do I specify a list of update sites and a list of IUs? Do I pass
multiple -artifactRepository/-metadataRepository/-installIU options to
the director application?
/Jesper
Re: finding out dependencies when building a product [message #532327 is a reply to message #532246] Sat, 08 May 2010 07:13 Go to previous message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Yes. You can pass either a comma separated list, or repeat the options.
- thomas
Previous Topic:site.p2.zip action does not produce zipped site in Hudson
Next Topic:b3 aggregator problem
Current Time: Thu Sep 23 19:14:35 GMT 2021
Powered by FUDForum. Page generated in 0.01652 seconds
