Declaring objects of enum types within EOL scripts [message #531925] |
Thu, 06 May 2010 13:48 |
Originally posted by: c.k.holmes.lboro.ac.uk
I have a metamodel containing a class:
class Table extends BlockElement {
attr ColourType backgroundColourName = "WHITE";
val TableCaption caption;
val TableSection[?] head;
val TableSection[?] body;
val TableSection[?] foot;
Where:
enum ColourType {
WHITE = 0;
RED = 1;
BLUE = 2;
YELLOW = 3;
ORANGE = 4;
GREEN = 5;
LIMEGREEN = 6;
LIGHTBLUE = 7;
LIGHTSLATEGRAY = 8;
I call an operation in an EOL script from ETL (which is run from an Ant
workflow) and want to declare a colour value, e.g.
var ok : Report!ColourType := Report!ColourType#LIMEGREEN;
However, this returns an error 'Report!ColourType not found'. Although I
can do this within the body of an operation:
<snip>
if (match.isMatching()) {
for (row in table.body.row) {
row.paintContents(Report!ColourType#LIMEGREEN);
} else {
row.paintContents(Report!ColourType#RED);
</snip>
So, clearly, the type is being resolved. Is this a problem with my
syntax? How can I declare the variable 'ok' (above) correctly?
Chris
Re: Declaring objects of enum types within EOL scripts [message #531926 is a reply to message #531925] |
Thu, 06 May 2010 13:52 |
I intended to show the following code fragment (which runs successfully):
<snip>
row.backgroundColourName := Report!ColourType#LIMEGREEN;
} else {
row.backgroundColourName := Report!ColourType#RED;
</snip>
Chris
Chris Holmes wrote:
> Where:
> enum ColourType {
> WHITE = 0;
> RED = 1;
> BLUE = 2;
> YELLOW = 3;
> ORANGE = 4;
> GREEN = 5;
> LIMEGREEN = 6;
> LIGHTBLUE = 7;
> LIGHTSLATEGRAY = 8;
> <snip>
> } else {
> </snip>
> Regards
> Chris
Re: Declaring objects of enum types within EOL scripts [message #531928 is a reply to message #531927] |
Thu, 06 May 2010 14:14 |
Hi Dimitris,
At least it wasn't me ... this time ;)
Thanks for your help.
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> You've hit https://bugs.eclipse.org/bugs/show_bug.cgi?id=286412 I'm
> afraid. Enumerations are not valid EOL types so I'm afraid you'll have
> to use the Any workaround (or omit the type altogether) until we get
> this fixed.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> <snip>
>> } else {
>> </snip>
>> Regards
>> Chris
>> Chris Holmes wrote:
>>> Hi,
>>> Where:
>>> enum ColourType {
>>> WHITE = 0;
>>> RED = 1;
>>> BLUE = 2;
>>> YELLOW = 3;
>>> ORANGE = 4;
>>> GREEN = 5;
>>> LIMEGREEN = 6;
>>> LIGHTBLUE = 7;
>>> LIGHTSLATEGRAY = 8;
>>> Ant workflow) and want to declare a colour value, e.g.
>>> Although I can do this within the body of an operation:
>>> <snip>
>>> } else {
>>> </snip>
>>> Regards
>>> Chris
Re: Declaring objects of enum types within EOL scripts [message #588888 is a reply to message #531925] |
<snip>
} else {
</snip>
Chris
Chris Holmes wrote:
> Where:
> enum ColourType {
> WHITE = 0;
> RED = 1;
> BLUE = 2;
> YELLOW = 3;
> ORANGE = 4;
> GREEN = 5;
> LIMEGREEN = 6;
> LIGHTBLUE = 7;
> LIGHTSLATEGRAY = 8;
> <snip>
> } else {
> </snip>
> Regards
> Chris
Re: Declaring objects of enum types within EOL scripts [message #588900 is a reply to message #531927] |
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> this fixed.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> <snip>
>> } else {
>> </snip>
>> Regards
>> Chris
>> Chris Holmes wrote:
>>> Hi,
>>> Where:
>>> enum ColourType {
>>> WHITE = 0;
>>> RED = 1;
>>> BLUE = 2;
>>> YELLOW = 3;
>>> ORANGE = 4;
>>> GREEN = 5;
>>> LIMEGREEN = 6;
>>> LIGHTBLUE = 7;
>>> LIGHTSLATEGRAY = 8;
>>> <snip>
>>> } else {
>>> </snip>
>>> Regards
>>> Chris
FUDForum. Page generated in 0.03595 seconds
