Re: Can't get SWTBot working with Helios 3.6M7 [message #531783 is a reply to message #531677] |
Thu, 06 May 2010 08:00 |
Jeff Johnston a écrit :
> I am trying to run SWTBot under Helios 3.6M7 and I keep getting:
> Exception in thread "WorkbenchTestable"
> java.lang.IllegalArgumentException: No Classloader found for plug-in
> org.eclipse.linuxtools.cdt.autotools.ui.tests
At a first glance, this does not seem related to SWTBot.
This means that the Helios platform was not able to resolve the org.eclipse.linuxtools.cdt.autotools.ui.tests bundle, because
EITHER * The plugin is not here
OR (more probable) * The plugin has an unresolved dependency
You should try to run the test with the OSGi console started (flagging the launcher with -console), and try the command "start org.eclipse.linuxtools.cdt.autotools.ui.tests". That will probably tell you why this bundle could not be loaded.
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
FUDForum. Page generated in 0.03477 seconds
