Home » Eclipse Projects » Remote Application Platform (RAP) » I create my custom Widget, How to show the changes for UI in js?(Use js code to change the ui content.)
icon5.gif  I create my custom Widget, How to show the changes for UI in js? [message #531469] Wed, 05 May 2010 02:49 Go to next message
this is my js code
var req = org.eclipse.swt.Request.getInstance();
req.addParameter( gmapId + ".address", document.body.innerHTML );
req.addParameter( gmapId + ".centerLocation", a );
alert("gettt::"+req.getParameter(gmapId + ".centerLocation"));
req.send();\\this code will run the LCA class
then this attribute "centerLocation" in my model. I add the listener for this model.
when change the attribute "centerLocation", I will add some logic for my rap view
IWorkbenchPage page = getViewSite().getWorkbenchWindow()
.getActivePage();
page.showView("org.eclipse.ui.views.PropertySheet");
but I can not find this view as a active view? what's the reason?
[Updated on: Wed, 05 May 2010 02:51] by Moderator
Re: I create my custom Widget, How to show the changes in js? [message #531548 is a reply to message #531469] Wed, 05 May 2010 07:41 Go to previous messageGo to next message
does your listener triggered at all? If not, maybe the event is fired in
a wrong phase. Use:
ProcessActionRunner.add( new Runnable() {
public void run() {
// Fire event here
to fire the event in the process action phase.
HTH,
Ivan
On 05/05/2010 9:49 AM, zezhenyan wrote:
> this is my js code
> for this model.
> my rap view
> .getActivePage();
> Thanks
Re: I create my custom Widget, How to show the changes in js? [message #531745 is a reply to message #531548] Wed, 05 May 2010 21:58 Go to previous message
Ivan:
It runs great!!
Thank you very much, you help me to solve a big problem.
You are my hero. Very Happy
Tyki
Previous Topic:Eclipse RAP and OSGi DS
Next Topic:Updates to upload widget
Current Time: Mon May 19 03:42:07 EDT 2025
Powered by FUDForum. Page generated in 0.03180 seconds
