Home » Archived » Buckminster » internalization build
internalization build [message #531315] Tue, 04 May 2010 14:29 Go to next message
Alex Kravets is currently offline Alex KravetsFriend
I want to build my RCP application for a specific language, is there facility present in Buckminster to help with this or do I need to take care of this myself?
thanks,
Alex
Re: internalization build [message #531368 is a reply to message #531315] Tue, 04 May 2010 15:36 Go to previous messageGo to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
Afaik,
The steps are to create a p2 repository for the combinations you are
interested in (platforms, window systems, languages, etc.).
Then, when creating the product zip (or equivalent), create the product
with the appropriate constraints set.
Does that help?
- henrik
On 5/4/10 4:29 PM, Alex wrote:
> thanks,
> Alex
Re: internalization build [message #531647 is a reply to message #531368] Wed, 05 May 2010 16:48 Go to previous messageGo to next message
Thanks Henrik,
In my target platform I added the babel plugins for my language. When I build p2 site all the nl_ru plugins make it there, but when I create the actual product I only see org.eclipse.equinox.launcher.nl_ru plugin there. Any ideas what am I doing wrong?
thanks,
Alex
Re: internalization build [message #531657 is a reply to message #531315] Wed, 05 May 2010 17:38 Go to previous messageGo to next message
May be putting translated plugins in target platform is not the right way to go because regardless of target.nl setting it builds for all languages in target.
Re: internalization build [message #531731 is a reply to message #531657] Wed, 05 May 2010 23:36 Go to previous messageGo to next message
Confused... don't you want all the language configurations in your
target platform to enable building results that are for different languages?
It is the step when you create the RCP application in installed form
(i.e. a ready to run zip) where you want to state the language that
should be used in the finished product.
Alternatively, you can run the director against the p2 repository and
produce an installation (i.e. "install") with any valid configuration.
Does this help?
- henrik
Re: internalization build [message #531749 is a reply to message #531731] Thu, 06 May 2010 02:27 Go to previous messageGo to next message
Yes, scratch my last comment, this is exactly how it's suppose to work.
thanks,
Alex
Re: internalization build [message #531938 is a reply to message #531749] Thu, 06 May 2010 14:39 Go to previous messageGo to next message
Henrik,
About my second question...
I changed my ant script to include target.nl parameter:
<java jar="${equinox.launcher.jar}" fork="true" failonerror="true" >
			<arg value="-application"/>
			<arg value="org.eclipse.equinox.p2.director"/>
			<arg value="-artifactRepository"/>
			<arg value="file:${repository}"/>
			<arg value="-metadataRepository"/>
			<arg value="-destination"/>
			<arg value="${destination}"/>
			<arg value="-bundlepool"/>
			<arg value="-profile"/>
			<arg value="${profile}"/>
			<arg value="-profileProperties" />
			<arg value="org.eclipse.update.install.features=true" />
			<arg value="-installIU"/>
			<arg value="${iu}"/>
			<arg value="-p2.os" />
			<arg value="${target.os}" />
			<arg value="-p2.ws" />
			<arg value="${target.ws}" />
			<arg value="-p2.arch" />
			<arg value="${target.arch}" />
			<arg value="-p2.nl" />
			<arg value="${target.nl}" />
			<arg value="-consoleLog"/>
			<jvmarg value="-Declipse.p2.data.area=${destination}/p2"/>
			<jvmarg value="-Declipse.p2.profile=${profile}"/>
		</java>
I am not sure if -p2.nl is the right parameter or even if this is the right place to put parameter, but when I run create.product action with target.nl=ru in supplied properties file only org.eclipse.equinox.launcher.nl_ru_3.5.0.v20091121043401 makes into plugins folder of the product. Why are other nl plugins don't make into the product?
thanks for your help,
Alex
Re: internalization build [message #531944 is a reply to message #531938] Thu, 06 May 2010 14:49 Go to previous message
Also, p2 repository is build with all nl plugins in place.
Previous Topic:XML weirdness in buckminster.cspex
Next Topic:team --> commit integration
Current Time: Tue Apr 16 13:48:01 GMT 2024
Powered by FUDForum. Page generated in 1.16999 seconds
