Where did my matches go? [message #531249] |
Tue, 04 May 2010 10:25 |
Originally posted by: c.k.holmes.lboro.ac.uk
I have an Ant workflow that compares two models using ECL returning the
resulting matchTrace object. The Ant workflow then runs a transformation
via ETL using the matchTrace structure, however the number of matches
reported in the 'post' section of the ECL script and the number reported
in the 'pre' section of the ETL script differ somewhat. Why is this?
<target name="A">
<epsilon.ecl src="${EclFile}" exportmatchtrace="matchTrace">
<model ref="${LeftModel}" as="Left"/>
<model ref="${RightModel}" as="Right"/>
</epsilon.ecl>
</target>
<target name="B">
<epsilon.loadModel name="${Document}" type="EMF">
<parameter name="modelFile" file="${DocModel}"/>
<parameter name="metamodelUri" value="${DocModelUri}"/>
<parameter name="readOnLoad" value="false"/>
<parameter name="storeOnDisposal" value="true"/>
</epsilon.loadModel>
<epsilon.etl src="${EtlFile}">
<model ref="${LeftModel}" as="MyModel"/>
<model ref="${Document}" as="Document"/>
<uses ref="matchTrace"/>
</epsilon.etl>
</target>
From ECL script:
<snip>
post {
'Match trace'.println();
('There are: ' + matchTrace.getMatches().size() + ' elements').println();
</snip>
Returns ==>
[epsilon.ecl - MyEclScript.ecl] Match trace
[epsilon.ecl - MyEclScript.ecl] There are: 372 elements
From ETL script:
<snip>
pre {
'Match Trace structure:'.println();
</snip>
Returns ==>
[epsilon.etl - MyEtlScript.etl] Match Trace structure:
[epsilon.etl - MyEtlScript.etl] There are: 177 elements
What happened to the other 195 matches? Am I interfacing ECL and ETL
correctly?
Chris
Re: Where did my matches go? [message #531255 is a reply to message #531254] |
Tue, 04 May 2010 10:37 |
Hi Dimitris,
Yes, I think I might. How do I do this?
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> This happens because before the ECL task exports the match trace, it
> removes matches with matching=false. Do you need to access these in the
> ETL transformation?
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> the resulting matchTrace object. The Ant workflow then runs a
>> transformation via ETL using the matchTrace structure, however the
>> number of matches reported in the 'post' section of the ECL script and
>> the number reported in the 'pre' section of the ETL script differ
>> <target name="A">
>> </epsilon.ecl>
>> </target>
>> <target name="B">
>> </epsilon.etl>
>> </target>
>> From ECL script:
>> <snip>
>> post {
>> </snip>
>> Returns ==>
>> From ETL script:
>> <snip>
>> pre {
>> </snip>
>> Returns ==>
>> correctly?
>> Regards
>> Chris
Re: Where did my matches go? [message #531256 is a reply to message #531255] |
Tue, 04 May 2010 10:41 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Chris,
Off the top of my head this should be possible if you replace
exportmatchtrace="matchTrace" with a nested <exports ref="matchTrace"/>
element inside <epsilon.ecl ...>. Please let me know if this doesn't
work and I'll have a closer look at this.
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> the ETL transformation?
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> and the number reported in the 'pre' section of the ETL script differ
>>> <target name="A">
>>> </epsilon.ecl>
>>> </target>
>>> <target name="B">
>>> </epsilon.etl>
>>> </target>
>>> From ECL script:
>>> <snip>
>>> post {
>>> </snip>
>>> Returns ==>
>>> From ETL script:
>>> <snip>
>>> pre {
>>> </snip>
>>> Returns ==>
>>> correctly?
>>> Regards
>>> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Where did my matches go? [message #531260 is a reply to message #531256] |
Tue, 04 May 2010 10:53 |
Hi Dimitris,
Your recollection is correct, it works :)
Many thanks for your assistance.
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi,
>>>> <target name="A">
>>>> </epsilon.ecl>
>>>> </target>
>>>> <target name="B">
>>>> </epsilon.etl>
>>>> </target>
>>>> From ECL script:
>>>> <snip>
>>>> post {
>>>> </snip>
>>>> Returns ==>
>>>> From ETL script:
>>>> <snip>
>>>> pre {
>>>> </snip>
>>>> Returns ==>
>>>> correctly?
>>>> Regards
>>>> Chris
Re: Where did my matches go? [message #588772 is a reply to message #531254] |
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> ETL transformation?
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi,
>> <target name="A">
>> </epsilon.ecl>
>> </target>
>> <target name="B">
>> </epsilon.etl>
>> </target>
>> From ECL script:
>> <snip>
>> post {
>> </snip>
>> Returns ==>
>> From ETL script:
>> <snip>
>> pre {
>> </snip>
>> Returns ==>
>> correctly?
>> Regards
>> Chris
Re: Where did my matches go? [message #588781 is a reply to message #531255] |
Hi Chris,
Dimitris
Chris Holmes wrote:
> Hi Dimitris,
> Best Wishes
> Chris
>> Hi Chris,
>> Cheers,
>> Dimitris
>> Chris Holmes wrote:
>>> Hi,
>>> <target name="A">
>>> </epsilon.ecl>
>>> </target>
>>> <target name="B">
>>> </epsilon.etl>
>>> </target>
>>> From ECL script:
>>> <snip>
>>> post {
>>> </snip>
>>> Returns ==>
>>> From ETL script:
>>> <snip>
>>> pre {
>>> </snip>
>>> Returns ==>
>>> correctly?
>>> Regards
>>> Chris
Re: Where did my matches go? [message #588793 is a reply to message #531256] |
Hi Dimitris,
Best Wishes
Chris
> Hi Chris,
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hi Dimitris,
>> Best Wishes
>> Chris
>>> Hi Chris,
>>> Cheers,
>>> Dimitris
>>> Chris Holmes wrote:
>>>> Hi,
>>>> <target name="A">
>>>> </epsilon.ecl>
>>>> </target>
>>>> <target name="B">
>>>> </epsilon.etl>
>>>> </target>
>>>> From ECL script:
>>>> <snip>
>>>> post {
>>>> </snip>
>>>> Returns ==>
>>>> From ETL script:
>>>> <snip>
>>>> pre {
>>>> </snip>
>>>> Returns ==>
>>>> correctly?
>>>> Regards
>>>> Chris
FUDForum. Page generated in 0.02655 seconds
