Re: EMF Compare problem comparing instances [message #533073 is a reply to message #532856] |
Wed, 12 May 2010 07:49 |
--------------020501050807050202000906
Hi Johannes,
Sorry, seems like I let your previous mail slip through (please use the
EMF newsgroup for EMF Compare questions).
I must confess we never tried comparing dynamic instances, and it isn't
part of our tests. Could you try with the latest version of EMF Compare
and raise a bug if it is still failing with a "feature not found" error?
Laurnt Goubet
Obeo
Johannes Albrecht wrote:
> Does anybody have the same problem?
> Is it even possible to compare instances created over the "create
> dynamic instance" dialog?
> Do you need more information?
> Johannes Albrecht
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020501050807050202000906--
Re: EMF Compare problem comparing instances [message #533140 is a reply to message #533121] |
Wed, 12 May 2010 11:44 |
--------------080301040803050308020009
We indeed have a know bug when comparing two instances of distinct
metamodels ... I didn't understand the problem to be it in this case though.
Ed Merks wrote:
> My guess from the description is that there are two instances of some
> Ecore model and then a dynamic instance of one is being compared against
> a dynamic instance of the other. Such things should not end up
> comparing as structurally equal because their Ecore models are not
> identical. But this is of course just a guess based on the symptoms.
> Laurent Goubet wrote:
>> Hi Johannes,
>> the EMF newsgroup for EMF Compare questions).
>> isn't part of our tests. Could you try with the latest version of EMF
>> Compare and raise a bug if it is still failing with a "feature not
>> found" error?
>> Laurnt Goubet
>> Obeo
>>> Johannes Albrecht
--------------080301040803050308020009--
Re: EMF Compare problem comparing instances [message #622884 is a reply to message #532856] |
Hi Johannes,
Laurnt Goubet
Obeo
> Johannes Albrecht
Re: EMF Compare problem comparing instances [message #622886 is a reply to message #533121] |
>> Hi Johannes,
>> found" error?
>> Laurnt Goubet
>> Obeo
>>> Johannes Albrecht
FUDForum. Page generated in 0.03245 seconds
