Home » Eclipse Projects » Standard Widget Toolkit (SWT) » how to catch home and end keys in SWT styledText
how to catch home and end keys in SWT styledText [message #530523] Thu, 29 April 2010 23:03 Go to next message
Lidder is currently offline LidderFriend
Member
I have implemented a spell checker on SWT StyledText widget. The basic logic is that the spell checking is done when the modifyText function fires. I calculate the annotations (squiggly lines) I need to draw and then draw them on the widget in the paintListener -> paintContol() method. There is one problem.
Let's say I write some incorrect text in the styledtext widget. The spell checker recognizes the modify event and run a spell check. The paint then draws the errors. Assume that the widget has SWT.SINGLE style. I can keep typing and the spell check keeps drawing the annotations. Now when I hit home to go the start of my text, the annotations are not refreshed as there is no modify event. I want to be able to capture when the "visible text" changes and redraw the annotations. Is there a way to do that?
Thanks for your help.
Re: how to catch home and end keys in SWT styledText [message #530984 is a reply to message #530523] Mon, 03 May 2010 08:59 Go to previous message
Praveen  is currently offline Praveen Friend
Member
The keys Home and End does not result in Modify event as it does not
cause in any modification of the text. I believe the only way is to
capture those events is through verifyKey event (ofcourse, or through
keyDown/keyUp) of StyledText.
Previous Topic:Metawidget has added SWT support
Next Topic:OLEControlSite and complete menubar loss
Current Time: Thu Oct 01 14:06:34 GMT 2020
Powered by FUDForum. Page generated in 0.02049 seconds
