Home » Language IDEs » PHP Development Tools (PDT) » Tired of setting up browser EVERY run(Could not open a Web browser because there are none configured. Check the Web Browser preferences. )
Tired of setting up browser EVERY run [message #530290] Thu, 29 April 2010 04:48 Go to next message
Hi all,
Every time I run Eclipse and want to debug, I get error message:
"Could not open a Web browser because there are none configured. Check the Web Browser preferences."
I go to Prefs and setup the web browser to "external". Then I can proceed with debugging.
If I exit Eclipse and start it again - everything goes the same way, I have to repeat Web Browser configuration again.
Version: 3.5.1
Build id: M20090917-0800
Re: Tired of setting up browser EVERY run [message #531124 is a reply to message #530290] Mon, 03 May 2010 15:21 Go to previous messageGo to next message
UP
Re: Tired of setting up browser EVERY run [message #531196 is a reply to message #530290] Tue, 04 May 2010 03:26 Go to previous messageGo to next message
BTW, what OS are you using?
Web browser configuration is stored in
workspace/.metadata/.plugins/org.eclipse.core.runtime/.setti ngs/org.eclipse.ui.browser.prefs
You can check it.
Also you can inspect workspace/.metadata/.log.
Re: Tired of setting up browser EVERY run [message #531199 is a reply to message #531196] Tue, 04 May 2010 03:44 Go to previous message
My OS is Ubuntu 9.10
This is what I see in .log:
!SESSION 2010-05-04 11:42:00.746 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_20
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=ru_RU
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.ui 4 0 2010-05-04 11:42:27.469
!MESSAGE Could not open a Web browser because there are none configured. Check the Web Browser preferences.
Previous Topic:Javascript Code Assist is not work?
Next Topic:How to get rid of useless views?
Current Time: Thu Jun 12 12:33:36 EDT 2025
Powered by FUDForum. Page generated in 0.04417 seconds
